Vacuum pump setup questions..
Old Mar 8, 2006 | 10:38 AM
Phil99vette's Avatar
7 Second Club
Default Vacuum pump setup questions..
We're installing a pair of vacuum pumps next week and have a couple of questions and hope someone can help.
We're welding 2 -10 bungs on the valve covers and running each side to the vacuum pump and the exhaust side is going to a catch can with a filter on the top and a petcock on the bottom. Do you need to add a relief port on the valve cover so its almost like a controlled leak or just leave it sealed?
Phil
Old Mar 8, 2006 | 11:47 AM
93LS1RX7's Avatar
Yes you need a vacuum relief valve or you can try to find it by making a hole
I welded mine into the drivers side valve cover where the PCV port was. I will try and link a pic....
Old Mar 8, 2006 | 11:49 AM
93LS1RX7's Avatar
Here is mine. You can see the vacuum relief valve on the far right of the pic almost at the firewall.
http://www.torquecentral.com/attachm...chmentid=14645
Old Mar 8, 2006 | 11:50 AM
93LS1RX7's Avatar
Summit sells them
Old Mar 8, 2006 | 11:52 AM
93LS1RX7's Avatar
One last post, you can get by with just the one bung on the passenger side cover. The vacuum across the motor will be consistant you dont need two.
I was alos told look at around 14-15" of vacuum at WOT
Old Mar 8, 2006 | 12:06 PM
7 Second Club
Thanks for the reply. We're using sheetmetal valvecovers with 2 - 10 bungs on each side. I figured there needed to be either a filter or a relief plug to pull from.
Phil
Old Mar 8, 2006 | 12:38 PM
strokedls1's Avatar
We didn't use a valve relief on ours because the size of the pulley was so big we were told it was not necessary. We'll have a better idea after the dyno. We used one -12an line into the valley cover, and so far it is working great.
Old Mar 8, 2006 | 12:42 PM
7 Second Club
StrokedLs1,
What intake are you using? Any pics of the valley cover?
Phil
Old Mar 8, 2006 | 12:55 PM
strokedls1's Avatar
Using a victor jr intake on an ls1 valley cover. I can take pictures tonite, but don't have any of the completed setup. Just finished the car last sunday.
Old Mar 8, 2006 | 01:04 PM
7 Second Club
Thanks, I figured it was a single plane intake. There is absolutely no room with the Fast or LS1/6 but I am going to find a solution. If you can take a pic it would be a great big help.
Old Mar 8, 2006 | 01:06 PM
7 Second Club
Is the valley cover steel or aluminum?
Old Mar 8, 2006 | 01:13 PM
strokedls1's Avatar
I don't know for sure. If I had to guess I would say alluminum. I'll snap some shots tonite for you. PM me an email address to send them to.
Old Mar 8, 2006 | 01:42 PM
MrDude_1's Avatar
the stock valley cover is cast alum. you could fabricate a thinner one if you wanted to.
i have seen motors that had gasket sealing problems from running a vac pump with no relief valve... i cant call it first hand experiance though, since i didnt own or run any of the motors.
i would run one if it was my car... besides, after a specific point, the extra vacuum is just creating more drag with the pump...
Old Mar 8, 2006 | 03:00 PM
7 Second Club
Sounds good, I am going to fabricate a tube that has a -12 connection on one end welded to the cover. Thanks!
Phil
