TR TRak
Old Mar 8, 2006 | 12:15 PM
GA/TA's Avatar
Default TR TRak
I haven't really heard alot about it, and the search didn't bring up anything either. It looks like it would be a good dd and track cam but does anyone have this cam or is their a TR guy i can talk to?
Old Mar 8, 2006 | 01:28 PM
Patrick G's Avatar
LS1 Tech Administrator
I've run this cam as a DD in my TA. It is bigger than the cam specs make it seem because the ramps past .050" are very aggressive. Even though it specs out at 231/234, it behaves more like a 236/234 XE-R cam. This is because it uses Comp's LSK lobes on the intake and XE-R lobes on the exhaust. I've made good power with this cam with both AFR 205 heads and AFR 225 heads. Don't know if it would benefit a stock head as much as a ported head, but it should work fine nontheless. Click signature for more details.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Mar 8, 2006 | 01:38 PM
ls1mongrel's Avatar
I got it in a a4 car and it drives fine , its a very streetable cam , not sure aobut the stock heads, I got afr 205's !
Old Mar 8, 2006 | 02:28 PM
GA/TA's Avatar
I was hopeing for around 400wrhp, i know it is very streetable, which is why i am trying to find out a good bit about it. I was orignaly looking at the MS3 but the power band is alittle to high for me. I know i need double springs for it but what about pushrods. Since no one has the cam on stock head do you think it will take alot away from it. If you guys are making 470 at the wheels with this cam and heads i think i should beable to meet my goals.
Old Mar 8, 2006 | 02:38 PM
Patrick G's Avatar
400rwhp is within your reach with the right supporting bolt-on parts and a good tune.
Old Mar 8, 2006 | 02:56 PM
ls1mongrel's Avatar
Im only making about 400rwhp lol !
Old Mar 8, 2006 | 03:09 PM
Patrick G's Avatar
But think about how similar your setup is with mine: Same heads, same cam, similar exhaust, etc. The 60-70 rwhp difference shows how an M6 puts power to the ground differently than an unlocked A4. Basically, you are putting down 400 rwhp for the entire 1/4 mile. I don't exceed 400 rwhp until my rpm climbs above 5000 rpm. Your Fuddle 3800 gobbles up a bunch of ponies as does the 4L60 E itself. Lock up the converter and you'd probably gain 30 rwhp...maybe 40.
Old Mar 8, 2006 | 05:30 PM
GA/TA's Avatar
I am planing on getting a set of heads soonner or later, does valve clearence an issue with some heads.
Old Mar 8, 2006 | 05:39 PM
GA/TA's Avatar
And do either of you have a soundclip or a vid of you car or a car with the TRak in it?
Old Mar 9, 2006 | 10:29 AM
GA/TA's Avatar
either of you?
Old Mar 9, 2006 | 11:49 AM
ls1mongrel's Avatar
I dont, Ill try and get one tonight, search trak in the video section on this site, there is a video of a t/a with a trak cam there !
Old Mar 9, 2006 | 11:54 AM
GA/TA's Avatar
Thanks
