LS1 balancer tool??
Old Mar 8, 2006 | 05:57 PM
alconk's Avatar
Default LS1 balancer tool??
Does anybody have a Kent Moore LS1 balancer installer tool?? I just bought one and have no idea how it works.. It's for a 6.0 LQ9 and I think it works for this also, so I was told. The pieces that came with it will not thread into the crank end, tool is much bigger so I have no idea unless they sent me the wrong one.
Old Mar 8, 2006 | 06:15 PM
2xLS1's Avatar
I've used the same one on several 5.3s, more LS1s than I can count and one 02 6.0L. They all used the same crank bolt too. Does the size and threads on the tool look like the crank bolt you took out?
Old Mar 9, 2006 | 06:07 AM
alconk's Avatar
No the ones in the kit are way too big??
Old Mar 9, 2006 | 07:04 AM
alconk's Avatar
Hello 2xLS1 I can't figure out how to PM you??? How do I do it?? Sorry for the ignorance!!
Old Mar 9, 2006 | 08:00 AM
Hodge's Avatar
Attached are pics of the damper installation tool J-41665. This tool has three pieces: An all-thread bolt M16x2 (about 8 inches long), a .25" thick washer (2" OD, 0.653" ID), and a spacer??? (not sure how to describe it) that clears the crank snout. I'll try to post the actual dimensions later.
Attached Thumbnails LS1 balancer tool??-j1.jpg   LS1 balancer tool??-j2.jpg   LS1 balancer tool??-j3.jpg
Old Mar 9, 2006 | 08:25 AM
kenp's Avatar
I don't know if I can explain this clearly enough, but....
The nut and washer need to be threaded back toward the bolt head. Then the piece you have in your hand in the 2nd photo slides on the bolt with the smaller hole toward the bolt head. Thread the long bolt into the crank after the balancer is placed on the crank. Once you have the long bolt threaded into the crank, you use the nut to push the cylindrical piece against the balancer and press the balancer back onto the crank.
Maybe someone else can explain it more clearly, but I tried.
Old Mar 9, 2006 | 08:27 AM
alconk's Avatar
You guys done AWSOM!!!! That don't look anything like what Kent Moore sent me. And thanks for the parts #too, I'll be calling them back today. Thanks again guys!!!!
Old Mar 9, 2006 | 10:09 AM
Hodge's Avatar
Dimensions on the piece to clear the crank snout are in the attachment. If anyone is interested in the autocad file, pm me.
Old Mar 9, 2006 | 10:11 AM
2xLS1's Avatar
Looks like that tool forces you to use a wrench to install the pulley. I prefer using a big ratchet and deep socket. The short all-thread tool I use can also be used as stop for the puller when removing the pulley.
