what is the stock preload?
Thats my take on it anyway.
Also, i want to state that while all hyd lifters do have a tendency to pump up, wether or not it happend depends very much on your setup, otherwise ever dyno graph would show a drop off in power.
i just dynoed after a fast intake and pushrods, according to the airflow rate increase from the fast intake and then the pushrods (which was noticeable after the pushrods, 12 g/sec increase in airflow WOT, 15 with the fast). I gained 25 rwhp which makes about 11 of it from pushrods. the valve was opening sooner, and you can see that as i put the new pushrods on the car.
Of course that doesnt mean you didnt see any, you could have really been on the ragged edge. I just doubt it myself.
Ive actually been considering trying a slightly longer pushrod myself, then dynoing right after with that being the only change. It would be worth it to me if it just quiets the valvetrain a little.
The internet is great for opinions. Most opinions I've read on this site say it CAN affect power.
Not knocking what your saying, just pointing out the opinion is on both sides of the fence.
But if too much preload can hang valves open ( to the point the car won't start and it backfires through the intake ) then wouldn't it make sense that a little less than that ( enough for the car to run ) would be down on power too?
Im going to add one of those disclaimers to my sig.
I put a piece of glass on the bench. Setup my dial indicater and put an old rocker arm on top of the PR's so that the dial indicater plunger didn't fall into the different size oil holes and set the other end on the flat surface of the glass. Measured the stock one and made that a zero point. Measured the comp 7.4...was .019 longer than stock. Measured the comp 7.425 which was .026 longer than the 7.4. Total difference in length from stock to a comp 7.425 was .045.
All this proves a comp 7.425 PR on a cam only swap (stock heads,stock head gasket) to the common 1.45x base circle cams is within ~.005 - .006 to having the stock preload assuming stock base circles are 1.553.
Something I found interesting is that when I adjusted the PR checker to what should be 7.40 it was .011 shorter than the comp 7.40 PR. One turn did equal .050 though.
