Head Cam Swap Started Any Advice?
SHOP VAC IS KING!
https://ls1tech.com/forums/generation-iii-internal-engine/450774-head-swap-tips.html
https://ls1tech.com/forums/generation-iii-internal-engine/451678-head-swap-no-coolant-mess.html
Another good thing is when yo go to a MLS gasket, like the GM ones or whatever, you'll never hav eto go thru the block scraping deal again.. I wish they would have just used that metal gasket in teh first place, sure would make things easier.
looks sexy
this is also a good time to remove your, A/C (save around 45lbs), remove egr,air,
and install an UD pulley, headers, new intake, high flow water pump/oil pump
and a catch can!....etc..
or any other parts you dont have yet....
have fun!
. lol main problem with me is its my daily driver and so i dont want it to take forever...how long do u think it'll take if u work on it an entire weekend doin things slow and right?
. Went and bought a shop vac and used it to suck the coolant out of the heads before pulling. Worked great
I don't think any coolant got into the bolt holes but nobody said anything about the oil from the top of the heads getting in there. Also been using the vac while cleaning heads to keep the junk from falling into the block. Scotch Brite pads work really well for cleaning the old head gasket material off the block. One more peace of advice, I was able to climb in between the engine and radiator support to get some good leverage to break the head bolts loose. To be continued....
fuerzaws6
