Ls6 heads on Ls1
Old Mar 15, 2006 | 09:57 AM
radcliffe18's Avatar
Default Ls6 heads on Ls1
just as the title states, i have the chance to buy brand new ls6 heads for my ls1, is this worth it? what will the gains be? any info is appreciated
Old Mar 15, 2006 | 10:22 AM
ilirw325's Avatar
Many will say no many will say yes. I say yes as long as they are 2002+ with the lightweight valves. Also make sure they dont tell you they do have the light weight valves just because of the 243 casting. There are a lot of 243 heads that have the standard stainless valves floating around out there from caddys and gto's.
Take the heads to a local spreed machine shop and have them touched up for a few more horse, bowl blend and whatnot
Old Mar 15, 2006 | 11:04 AM
you2slo's Avatar
Depends on the price. If they are an amazing deal, go for it. If not, check out some of the sponsors for some inexpensive heads.
Old Mar 15, 2006 | 11:17 AM
PREDATOR-Z's Avatar
I say no since you can get the same castings (243) ported with stainless standard valves for (~$875>900)
Livernois, TSP and PP do them
Much cheaper than a non ported set of LS6 with sodium valves (~$1200) and more performing too.
Old Mar 15, 2006 | 11:18 AM
bowtieman81's Avatar
Agree. The valves would be appealing. Keep in mind you can buy new LS6 heads ported from TSP for 900$.
Old Mar 15, 2006 | 12:18 PM
LivernoisMotorsports's Avatar
Our heads are factory 243 (LS2/LS6) castings. They can be found on our site at the folloing links:
Stage 1
Stage 2
Stage 3
If you have any questions, you can pm me or call us at 313-561-5500.
Thank you
Regards,
Rick LeBlanc
Old Mar 15, 2006 | 12:45 PM
CKZ's Avatar
CKZ
Rick,
Any dyno/track numbers on the Stage 2 LS6s?
Old Mar 15, 2006 | 12:52 PM
Gunnar@Patriot's Avatar
We can sell you a pair of CNC ported 243 castings with OEM (non-sodium) valves and LS6 valve springs for $865.00. Or we can give you a great price on porting your heads. Give us a call and we can go over all the options.
Old Mar 15, 2006 | 05:03 PM
how much greater are your CNC ported 243 castings with OEM valves and ls6 valve springs then regular Ls1 heads?? do you have any dyno numbers because 865 is within my budget
