So...who wants to talk me out of another 224 cam??
Originally Posted by Ragtop 99
Of those listed, the TR 230/224 is best cam for your needs.
A 228/228 111 108 would make great torque. With 3.42s, the key is to keep your IVC early and LSA low to make good low end and midrange torque. With a good exhaust installed you could even run a 228/224 110 108. That will give a very strong midrange and still pull to 6300. If I had 3.42s, I'd actually advance it another degree, but I like lots of low end power on the street.
If you want the max power, order them on LSK lobes (e.g. 227 and 223 lobes).
I believe the IVC is 43° on the TR230-111 and the cam has no advance. I thought about advancing it 2° giving it the IVC of 41° and the ICL of 109°.
Thoughts?
That comes out as IVC = 46* based upon my calculations so a couple degrees advance would be good.
Have them grind it straight up. When you do the swap, put in an adjustible timing change and use the chain to advance it 2 - 4*. That way if the top end isn't what you like, you can put it back without throwing the cam away.
I use the spreadsheet that has been circulating for a couple years. Looking at the formulas in Excel it is:
IVO = (duration/2) - ICL [Note: negative number = ATDC]
IVC = Duration - IVO - 180
