All new CRANE BAD BOY cam specs!
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You might want to consider getting a few more bolt ons first and maybe a good set of heads. These cams are definitely in my playing field, but they are gonna be a dog on the street for daily driving unless you have a premier tune and some gears or a decent stall.
Hey gollum....why did you roll your eyes at the ramp rate?
If it is between the xe and xe-r lobes it would be a very good performer.
The futral cams are a good example.
What do you guys think of this cam? It uses the same lobes as the bad boy cams....the zcam lobes.
http://www.sdpc2000.com/catalog/3876...0-0600-113.htm
Think I should go out on a limb and try it out?
A mate here in OZ had a 232-242-110+0 with around 0.550 lift and it was gay on his stock heads 346 with a 3800 stall. It had no guts at all till 3500RPM (as stated) so needs a 4400+ stall minimum on a A4. It idled nice and lopey though. Definately not a streeter IMO. Made same power as my 212-220-112+2 with a 3200 stallie, so needs headwork to really shine.
