Just got news...ETP 225 flow numbers...added full flow numbers...
#41
![Arrow](https://ls1tech.com/forums/images/icons/icon2.gif)
Originally Posted by Fireball
I'll be running the 4" bore version on my 346
Fireball, wouldn't the 225's make more hp at the top but lose hp and torque at the low and mid-range? Which would be fine for the track I'm sure, but why not go all out with the 240's then?
#42
Originally Posted by Cobraeater
That's interesting, the 225 numbers on a 3.900 bore are virtually identical to the 215 numbers on the same bore from your website, so what's the point in getting 225 heads on a 3.900 bore?
Using 225's on a 3.900 is a good idea in some cases. If it is higher RPM and compression you will need the port volume. If it is a 346 daily driver pump gas head/cam and a few bolt ons then the best thing is to use a 215. It is all on the combination of what you are doing. For a stock bottom end with a supercharger I like the 225's. If it is really radical supercharged ( over 18 psi and 7000rpm ) or Race ( high compression 14:1 +, solid roller etc. etc. ) only 346 the 245's are what I like to see. Thats just my thoughts, everyone is different in the way they like to build things.
#43
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Why?
