Getting really inpatient
Old Mar 18, 2006 | 02:51 PM
gus99ssm6's Avatar
Default Getting really inpatient
how am i goin to get the seal in the timing cover seal? any suggestions? i tried hammering not getting anywhere. thanx in advance.
Old Mar 18, 2006 | 03:09 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Mine went in real easily. Just give it a few good wacks with a block of wood.
Old Mar 18, 2006 | 04:19 PM
Happy Jim's Avatar
I put mine in a couple of weekends ago, used a block of wood resting on top and tapped gently with a hammer - sod all use that was , then tapped gently on the seal all the way round - same result . Finally put the block of wood back on the seal, picked up the 2lb hammer and whacked the **** out of the wood - Perfect not pleasant and a little unsettling to hit it that hard, but worked so yippee!
Rgds
Jim
Old Mar 18, 2006 | 04:21 PM
vettenuts's Avatar
Mine went in without tools, fingers only. What part number are you installing? Don't damage your cover, something sounds amiss.
