MS3 Cam/ Gears?
Old Mar 20, 2006 | 10:46 PM
nokeman's Avatar
I would definately get a higher stall than 3000. Something more like 4200 or so. And nothing less than 4.10s. It is possible to drive it with less than 4.10s but you still wont be getting its full potential. That cam loves the spray apparently so you will have a blast. I would also get a set of heads and with heads, MS3, and a 150 shot, that freekin car will be screaming.
Old Mar 20, 2006 | 11:28 PM
white2001ta's Avatar
3.73 with a 4000 stall works fine for me.
Old Mar 20, 2006 | 11:43 PM
FUN LS1's Avatar
Originally Posted by HottLS1Z
Yeah I have the girdle had it when i broke y last set of 373 and 410 gears, what is this about welding the axel tubes though???
You look at the 12-bolt and it's got a nice smooth weld all the way around, but my 10-bolt (and others, I've heard) is just spot welded to the tubes. Welding the steel braces sounds like a pain unless you can have the pieces easily fab'd and welded. But if you've seen a Strange 12-bolt and the braces that are cast in between the axles and the pinion, you'll get what I mean. The whole point of both is help the rear keep its shape.
Old Mar 20, 2006 | 11:44 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Man, this is TSP cam madness around here lately!
