Lifter Question?
Old Mar 20, 2006 | 11:54 AM
JPH's Avatar
JPH
Default Lifter Question?
Just wondering how many guys run stock lifters with there aftermarket cams. How much duration/lobe lift and spring pressure will the stock lifters handle, and how many miles on a stock lifter would you give it before replacing it. Thanks
Old Mar 20, 2006 | 12:36 PM
conan's Avatar
I ran the stockers with my old setup TR224 563, 28k on the clock. I using comp's oem replacement lifters with the cam in my sig.
Old Mar 20, 2006 | 12:42 PM
GuitsBoy's Avatar
Many Big Block marine engines use these same OEM GM lifters with 200#/600# springs. The stockers should be able to handle quite a bit.
Old Mar 20, 2006 | 01:52 PM
vettenuts's Avatar
I am switching to Morel's on my head change coming up in a few weeks. there may be some oiling issues with the stockers when they set lower in the bore due to the smaller base circle on aftermarket cams. I am not taking the risk.
