Need help calculating DCR
Old Mar 20, 2006 | 12:03 PM
Joel_SS's Avatar
Default Need help calculating DCR
I have a DRC calculator but it keeps telling me my DCR is around 10.1 and that seems way high based on my setup. Cam is a 226/234 112. Intake close 41 degrees ABDC. See pic. Am I doing something wrong?
I am trying to calculate for my new motor.. Here are the specs. I am going to use the GM MLS head gasket.
LME 347
Weiseco 3.905 pistons
CA Dura Moly Rings
Stock Rods and Crank
ARP rod bolts
Fedral Mogul Main Bearings
Clevite rod bearings
Dura Bond cam bearings
Balanced and blueprinted
Patriot Stage 3 heads 2.055/1.57 59CC
Attached Thumbnails Need help calculating DCR-dcr1.jpg   Need help calculating DCR-dcr2.jpg
Old Mar 20, 2006 | 12:15 PM
Patrick G's Avatar
LS1 Tech Administrator
You have to use the IVC figure at .006" lift, not .050".
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Mar 20, 2006 | 03:25 PM
99ssleeper's Avatar
you also want to input -.007 for the clearance height because the pistons come out of the hole and you want to subtract this measurement.
pat g is right...you'd need the advertised IVC....41° is where the crank is whent he valve is .050" off the seat. ADV should be a larger number...probably around 50 is my guess.
Old Mar 20, 2006 | 03:29 PM
99ssleeper's Avatar
also, where do you get .061 for quench? quench would be gasket thickness - clearance height....or .061-.007 = .054.
what doesnt make sense is that if you do it that way you are factoring the clearance height twice.
try this...forget what i said before and use .061 for the quench and use -.007 for the clearance height. it should calculate your quench and clearance volume from that. to check it, try doing .000 clearance height and .054 quench and see if you get the same answer.
Old Mar 21, 2006 | 09:15 AM
Joel_SS's Avatar
Thanks for the input! My cam card does not have the IVC figure @ .006. Is there anyway to calulate based off the .050 number?
Old Mar 21, 2006 | 09:17 AM
SideStep's Avatar
Maybe, where did you get the cam from (Comp, Crane, Lunati, etc...) and what cam lobe "profile" is it built on. Also need the ICL (advance)...
Old Mar 21, 2006 | 09:23 AM
Joel_SS's Avatar
It is a Lunati cam. I will take a pic of the cam card so you all can see it.
SideStep's Avatar
Cool....
Old Mar 23, 2006 | 10:41 AM
Joel_SS's Avatar
Here is a pic oy my cam card. Any ideas>?
Old Mar 23, 2006 | 12:05 PM
99ssleeper's Avatar
I'd give Lunati or the cam grider a call to find out for sure. The other way to get it is to gave the cam put on a Cam Doctor and have the specs read. A performance shop around your area may have one. It will give you lift and duration at any point on the lobes.
