can i run a small camshaft with the stock heads?
freind of mine called me up, he said"dude i can put a cam in" and i sed "dont u need heads too" he really doesnt know but is most likely sure that"no u can run it with the stock head"
guys is this possible? can i run a small cam with the stock heads or is it more complicated then that? and if this setup is possible wut cam should i get, and what gain will i see?
thanks, much appreciated
ryan
ryan
Originally Posted by HawaiianZ28Rider
do i hav to do antyhing real extensive? i jus wanna take the old cam out and slide the new cam in...but i guess that not the case is it?
jezuz christ im not even 1 pge into that sticky, thas a lotta info to soak up lol!!
and i jus fnished half of the sub discussion parts, man the tr's and comps are competitive...i dont know whos is better
do u guys know? please doont fight too
im on tr website, and im looking at all the 224's
i see:
1)TR224/224-112
2)TR224/224-114
3)TR224/227-114
which cam fellas?
and dont worry, im gonna read that whole sticky....jus not at 1130 at night
i see:
1)TR224/224-112
2)TR224/224-114
3)TR224/227-114
which cam fellas?
If you have emissions requirements stick to the 114 LSA - it will be easier to get to pass. The 112 LSA will make a little more power and the idle will have more "lope" to it.
To get the benefit of the cam you should really start with long tube headers.
What casey02ws6 said. And like eric01ss make sure you get the pushrods right, and CHANGE THE VALVE SPRINGS. A set of 918's will do the trick. With a small cam you can re-use the stock retainers with those springs.
