Does anyone make for 98's
Old Mar 23, 2006 | 07:42 PM
mypoorLS1's Avatar
Default Does anyone make for 98's
Do any of the aftermarket comanies make a head for perimiter bolt valve covers. I know I would only have to change valvecovers but want to keep the 98 look. I've tried the search but can't find anything.
Old Mar 23, 2006 | 08:17 PM
slowpoke96z28's Avatar
i don't know of any compaies that do, but i am sure your local automotive machine shop could hook that up, it would require measuring, adding screw bosses in the right places, and then drilling and tapping them. i can't imagine it being too difficult.
Old Mar 23, 2006 | 08:19 PM
SUX2BU's Avatar
only thing i can think of is getting some 98 perimiter heads and get them ported.
Old Mar 23, 2006 | 08:22 PM
mypoorLS1's Avatar
All the benefits of these new aftermarket castings are incredible. I thought about porting 98 heads but think it would be better to have an aftermarket casting.
Old Mar 23, 2006 | 08:35 PM
GTA91's Avatar
My ported '98 castings are doing just fine
Old Mar 23, 2006 | 09:09 PM
mypoorLS1's Avatar
Not saying ported heads aren't fine but look at the solid numbers being made with all the new heads. Look at the torque curves and peak numbers. Much better IMO
Old Mar 23, 2006 | 09:40 PM
SUX2BU's Avatar
Yeah your right aftermarket castings are where tha butters at.
can't wait till i can afford some 11* ET heads.
BTW why do you like the look of 98 heads? i HATE taking thgose damn valve covers off.
Old Mar 23, 2006 | 10:01 PM
jrp's Avatar
jrp
SN95 Director
somebody does or did in a prototype or production aftermarket head that had both the centerbolt and perimeter bolt provisions, i just cant rememeber who
Old Mar 23, 2006 | 10:49 PM
turbotacoma's Avatar
I have a set of ported 98 heads for sale.
http://www.ls1miata.net/gallery/album01?page=2
http://www.ls1miata.net/gallery/album01?page=3
I have them listed in the for sale section.
Old Mar 23, 2006 | 10:53 PM
i guess the machine shop route on center bolt pattern heads is out of the question? any center bolt head can be converted to perimeter style with a little, and i mean a little, work. any metal working shop that is good with aluminum should be able to do it fairly easy. call a couple machine shops and/or metal working shops in your area and see what they can do. you'll be suprised with the amount of craftsmanship some of those guys have. just trying to help, though. its your car and your money.
Old Mar 23, 2006 | 11:51 PM
mypoorLS1's Avatar
Sounds like this may be the only alternative. I had given this some thought but was kinda waiting to see if someone was gonna make these heads. I know that edelbrock had talked about it but that was before the release of their heads.
Old Mar 23, 2006 | 11:57 PM
SUX2BU's Avatar
Yeah your pretty much SOL cause everyone i know hates the perimiter heads. so i doubt they will make a whole seperate casting for them.
Old Mar 24, 2006 | 12:12 AM
iMpoSStoR's Avatar
i know that patriot has some perimeter style heads. they are 899 i believe.. also im not to sure on this one but if you call AFR they might be able to make them perimeter valve cover style.. i think its on option to have both styles.. but then again im not to sure on that one so dont quote me..
Old Mar 24, 2006 | 12:14 AM
2xLS1's Avatar
Patriot Performance has LS1 Stage II Perimeter Bolt Assy heads for $1095/pair. Part# 2007.
Old Mar 24, 2006 | 01:43 AM
mypoorLS1's Avatar
Patriots are still an oem casting.
Old Mar 24, 2006 | 03:16 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well, that is gonna be your best bet. They are the only ones that I have heard of that offer "perimeter performance" if you will. Plus you will only be toying with the fact that you would be losing 10 rwhp at the most probably on a naturally aspirated motor unless someone like ETP or AFR made one. The demand is not high enough. Most people would just assume to get rid of those heads and just replace coil brackets and valve covers for a small price and get a newer style head.
Old Mar 24, 2006 | 04:26 AM
LS1FIRE's Avatar
I have PRC permiter bolt heads
Old Mar 24, 2006 | 04:33 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
How long have you had those heads? And where from?
Old Mar 24, 2006 | 04:40 AM
LS1FIRE's Avatar
Couple months. And from Teaxs speed.
Old Mar 24, 2006 | 04:41 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That was what I thought. Is it advertised on their site?
