TRAK cam installed.
Old Mar 31, 2006 | 12:10 PM
spazzyfry123's Avatar
I have been considering this cam for a while and thought it was the one I would end up getting, but I didn't realize it had that much lift until now! I looked heavily into the cam, but for some odd reason, I over-looked its lift That might be a little too much for comfort. If there was some way I could use this cam, I would want to retain my stock heads and not have to cut the pistons. I just think that is way too much work to be done for my intentions. This is my daily-driver car and the only internal work I was planning on doing was a cam. In fact, I think the only performance mods I have in mind are full exhaust, new intake maybe, cam, and a tune (and if the bug keeps on biting...N2O ). From there is cosemetic stuff-ola. It's almost orgasmic to hear a big loping cam, and this one sounds like Hell is opening its doors. So, any way to use this as cam only without having to cut out the pistons...?
Bump...
Old Mar 31, 2006 | 01:17 PM
Patrick G's Avatar
LS1 Tech Administrator
Bump...
I think some of you guys don't understand the connection between lift and piston to valve clearance...there isn't any! When the valve is at maximum lift, the piston is near bottom dead center. You get piston to valve clearance issues when the piston approaches top dead center. Hanging a valve open too long (duration) is what causes piston to valve clearance issues.
For example: A 244/248 .500/500" cam has much worse piston to valve clearance than a 224/228 .700/.700" lift cam. Lift is not why you need to flycut. Larger duration is. Big lifts require better setup with springs, but that's about it.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Mar 31, 2006 | 04:04 PM
I am fairly knowledgable about cars and what makes them tick, but it's the internal stuff that boggles me (just how everything works in perfect unison to perform so well is amazing ) May this be the engine itself or the transmission or the pumpkin out back. I understand how they work in general, but specific links between things make my mind scramble. However, I absolutely love to learn about it. That's why I am always on here
But to remain on topic...Is it by chance that some do not have to do any type of piston-cutting with this cam and some do? Or is it because of the different setups people use with a specific cam (Let's say that two different people with two different heads are using the TRAK to be more specific)? Let's use the thread-starter as an example. He has different heads than I do (6.0L I believe? Where-as I still have factory heads and will more than likely keep them). Would this one thing by itself be the cause of piston-cutting (assuming that everyone is using the same valve-springs and push-rods and valves and so on...)?
I hope that made a little bit of sense...
Old Mar 31, 2006 | 04:10 PM
Patrick G's Avatar
With stock heads, there is no P to V clearance issues with the TRak cam. When running ported heads with milling and/or larger diameter valves, the clearance between the valves and the pistons is reduced, making it necessary to check P to V clearance. If you plan on keeping stock heads, you should have no reservations about running the TRak cam (from a P to V standpoint). Not everybody wants to take the time to set up the springs properly to run the TRak cam though. Basically, you'll need 7.450" pushrods and Comp 921 springs, Ti retainers and shims to get the spring height to within .050" of coil bind to work best with this cam. And don't forget to budget for a good tune.
__________________
Old Mar 31, 2006 | 04:31 PM
This won't be for a while, so I've got time. Or maybe it'll be sooner than I think...I will be taking the guy that hit my car and ran to court after insurance settles everything...perhaps I will get a nice settlement to get this done But anywho, thanks for the great help! When I do this, it will be done exactly right. I will not cut any corners (other than avoiding new heads ) I wasn't aware that I would be in need of new pushrods, however I am not a person that plans things out very well, but when it comes to my automobiles, I plan everything months in advance. So I guess I will go ahead and start now...
  • TRAK cam
  • Comp 921 springs
  • 7.450" pushrods (?)
  • Titanium retainers and shims (not exactly sure what these are)
This is just the actual parts needed...Not including the labor needed to install and the tune that will be needed...I have a six-speed, so no stall needed. Also, are new gears needed?
Am I missing anything?
Old Mar 31, 2006 | 06:11 PM
FunkyTownFBody's Avatar
4.10'ssssss!
I don't think you'll need the shims for the 921 springs... although I could be wrong?
Old Mar 31, 2006 | 06:21 PM
HOSS's Avatar
Patrick, I am running the 7.425 PR, when Mike checked it, it was right at perfect for pre-load from what he told me.
Originally Posted by FunkyTownFBody
4.10'ssssss!
Yeah, if it is required that I get gears, it will more than likely be 4.10's or 3.73's. But they don't really matter to me, so I will only get them if it is necessary.
P.S. Sorry for hijacking the thread...
Old Mar 31, 2006 | 07:18 PM
ThirdGenLS1's Avatar
4.10'ssssss!
I talked to Geoff today about this cam and others using a LSk lobe, but anyways he told me you NEED to shim the spring.
Old Mar 31, 2006 | 10:23 PM
WS6FirebirdTA00's Avatar
yeah on stock heads it puts him right around 0.090" preload.
Old Apr 1, 2006 | 06:27 AM
Good to know, thank you!
Old Apr 1, 2006 | 11:47 AM
  #32
Louie83's Avatar
Originally Posted by Ohio Bird of Prey
Wow. I had to flycut my pistons to make er fit but I think it will be worth it.
Car idles with my old modified Predator tune but is waaaaay lean (13.8) and needs way more timing (25 degs). Sounds bad as hell already.
Woohoo, fellow beavercreekian's got some rumble!
I haven't seen your car since all the F-Bods met up at the BW3's in beavercreek. I would like to see it now, bet it's bad ***.
Old Apr 1, 2006 | 07:46 PM
  #33
Ohio Bird of Prey's Avatar
Hey man whats up? I might be taking mine apart again. Geoff at Thunder told me it is important to shim the springs within at least .050 in. of coil bind for maximum performance. I was in too big a hurry and skipped that.
the car sounds mean but is down on power. Granted I need a tune and will get one soon I think I've some rework to do. My heads may be a problem
but that is yet to be proven.
Old Apr 1, 2006 | 09:35 PM
  #34
What you put down.
Old Apr 2, 2006 | 12:51 PM
  #35
kick_*ss's Avatar
Boy am I glad to see everyone happy with this cam, I just picked one up for my GTO and now it sounds like I am just going to have to swap the TR224 out of my SS and put one in there also.
Old Apr 2, 2006 | 12:56 PM
  #36
yea this cam seems to have a lot of thought behind it
Old Apr 2, 2006 | 10:40 PM
  #37
So running it with stock heads shouldn't be a problem?
Old Apr 2, 2006 | 10:57 PM
  #38
HOSS's Avatar
nope, not at all
