TRAK cam installed.
Old Mar 27, 2006 | 11:29 AM
Ohio Bird of Prey's Avatar
Default TRAK cam installed.
Wow. I had to flycut my pistons to make er fit but I think it will be worth it.
Car idles with my old modified Predator tune but is waaaaay lean (13.8) and needs way more timing (25 degs). Sounds bad as hell already.
Old Mar 27, 2006 | 11:34 AM
WS6FirebirdTA00's Avatar
damn right, put one in HOSS's car and it sounds wicked!
Old Mar 27, 2006 | 11:35 AM
HOSS's Avatar
Put TRak in Saturday, stock heads here, damn things a monster, shakes the **** out of the car. Kinda half tuned right now, but there is not traction in 2nd, and I love the sound!
Old Mar 27, 2006 | 11:38 AM
ls1mongrel's Avatar
GEt it tuned, you will love it !
Old Mar 27, 2006 | 12:31 PM
it will be here shortly, gotta fix an exhaust leak so the wb wont read screwy
Old Mar 27, 2006 | 06:32 PM
8banger's Avatar
I LOVE mine so far. Getting a tune tomorrow night!
Old Mar 27, 2006 | 06:34 PM
~JOSHUA's Avatar
What are the specs on the TRAK?
Oh yeah... congrats on the install.
Old Mar 27, 2006 | 06:44 PM
advertised is 231/234 .640/.600
Old Mar 27, 2006 | 06:46 PM
ClifZ28's Avatar
How streetable is that Trak cam?
Old Mar 27, 2006 | 06:49 PM
Cool
Mine was ground at 232.5/235.5 Duration, .648/.601 Lift 112 lsa
I pulled a TR224/224 .558/.558 112 lsa and I ran 11.9's with that one.
This TRAK has a whole new sound. I mean like big block sounds.
Old Mar 27, 2006 | 06:53 PM
~JOSHUA's Avatar
I love my 236/236.... but damn .640 lift!!! Holy ****. No wonder you had to flycut especially with milled heads. That's way too close for comfort for me. You'd better have the best valve springs known to man with that lift, rpm, and clearance. Wow.
Old Mar 27, 2006 | 06:58 PM
yeah its big, scary big when you are putting the rockers on and see how low that **** goes!!!
Old Mar 27, 2006 | 07:05 PM
Man, thats the truth. I went with Thunders recommendation of 921 springs.
They cost more but should be worth it. I can't wait to get er tuned and at the track. I might try a set of slicks this year too. That should be real good on the 10 bolt. hee hee
Old Mar 27, 2006 | 07:20 PM
98redorangeta's Avatar
Yeah your ten bolt might be giving out if you run slicks this year. I think you might be geting the car tunned sooner than you think
Old Mar 28, 2006 | 09:35 AM
With your help Mark and Jeff's I'm sure we'll make some great numbers both on and off the track.
Old Mar 28, 2006 | 09:37 AM
ls1mongrel's Avatar
Very streetable with a tune !
Old Mar 31, 2006 | 08:02 AM
HOSS's Avatar
I got to race a procharged SS last night, i think he is at 430/415 on 5lb's of boost. He got the initial jump, but after that, we were dead even. Still got a lot of tuning on it to do too, I may have just been lucky though.
Old Mar 31, 2006 | 08:35 AM
SVT THIS's Avatar
How big of a power difference is there between the TRak and TRex? I had been considering the TRex simply because you can't get any more aggressive on a stock motor. Is the TRak at all similar to the MS3?
Old Mar 31, 2006 | 08:51 AM
FunkyTownFBody's Avatar
Soundclip anyone?
Anybody know if these will fit with stock heads? What heads definitely fit without flycutting? I'm looking at PRC CNC Ported Heads... I think this cam would work since they are supposed to good for low P2VC
Old Mar 31, 2006 | 09:36 AM
he makes 445/415, but with you gears since he is on stock gears, i dont see a problem in you hanging in well
