What is YOUR A/F at?
Old Mar 28, 2006 | 07:50 PM
BriancWS6's Avatar
Default What is YOUR A/F at?
I am interested in what A/F everyone runs with their bolt on, cam only, or heads/cam car. I was always under the impression that you wanted to stay right around the 13.0 range. What is the highest that you can SAFELY run before you start to shorten the life of your car?
What A/F does it need to be to be safe with a dry shot? In the mid 12's? High 11's? Just looking to see what everyone else is at compared to me. Post up!
Old Mar 28, 2006 | 07:51 PM
Ksett's Avatar
Cam only 13.0
Old Mar 28, 2006 | 07:53 PM
gillbot's Avatar
Mine is about 13.0. Graph is here: https://ls1tech.com/forums/dynamometer-results-comparisons/476349-tr230-224-a4-dyno.html
Old Mar 28, 2006 | 08:04 PM
redtail2426's Avatar
im gonna tune mine to 12.5-12.6 or so.Its a street car and dont care to run it at 13.
Old Mar 28, 2006 | 08:32 PM
GuitsBoy's Avatar
I think 13:0 is still pretty safe, but watch it when it starts spiking to 13.3 in places. Some N/A races lean out as far as 13.5 but thats way lean for my taste. I shoot for 13:0 but try and err on the side of extra fuel.
Old Mar 28, 2006 | 08:38 PM
if the gas around here wasnt so crappy i would run 13.0,but i just dont trust it
Old Mar 28, 2006 | 09:12 PM
BriancWS6's Avatar
Great responses guys! Here's a pic of my graph, you can see the A/F is a bit lean.....I am going back soon to try and get the MAF to compensate for the dry hit, gonna add some fuel back in there to make it safer.
Attached Thumbnails What is YOUR A/F at?-brian_hendricks-ws6-after-tune.jpg
Old Mar 28, 2006 | 10:24 PM
Robinator's Avatar
I am 12.8 across the board.
Old Mar 28, 2006 | 10:28 PM
black01_WS6's Avatar
I am running at 13.0 across the board. yours does seem to be a bit on the high side, especially for a dry shot. I would probably run it at around 12.8 or so for safety.
Old Mar 29, 2006 | 05:36 AM
vettenuts's Avatar
My AFR at 6,000 RPM is around 12.2:1. Tuner keeps a safe street tune despite what seems to be the internet logic.
Old Mar 29, 2006 | 05:58 AM
Billiumss's Avatar
On the dyno - 12.7-12.8
On the street - 12.9-13.0
N20 - 11.5-11.8
Old Mar 29, 2006 | 07:49 AM
GuitsBoy's Avatar
You guys will likely see some KR before you have to worry about melting ****. I dont see the slightest bit of KR at WOT with 10.85:1 compression and 13.0 Air/Fuel.
Old Mar 29, 2006 | 08:11 AM
FDLS1's Avatar
Where are you guys measuring it at, the tail pipe? or do you have a wide band O2 pluged in after the headers?
Old Mar 29, 2006 | 08:17 AM
GuitsBoy's Avatar
I measure with a wideband in my X pipe, and had my readings backed up on the dyno with a dynojet wideband at the tailpipe. The two numbers matched perfectly.
Old Mar 29, 2006 | 09:15 AM
FDLS1's Avatar
Thanks for the response and would it matter if I just pluged it into one bank?
Old Mar 29, 2006 | 09:18 AM
GuitsBoy's Avatar
No, thats perfectly acceptable to do. Just be aware you may overheat the sensor. Its not likely but it does happen.
Old Mar 29, 2006 | 11:15 AM
Ryan02SS's Avatar
12.8-1 LM WB Dyno Tailpipe
Street is stays 13.0-1
I've ran 3 different Cam and H/C setups with this above and have not had a single problem in 3+ years.
As BilliumSS said above 11.5-11.8 for the N20.
Old Mar 29, 2006 | 11:21 AM
radkon's Avatar
We tried 12.8 on mine but put out a few more ponies at 13.2 with 0 Knock
Old Mar 29, 2006 | 11:29 AM
Robinator's Avatar
My tuning was done with the sensor pluged into the first O2 bung and completed with LS1 edit on a dyno.
Old Mar 29, 2006 | 01:55 PM
lowchevy2go's Avatar
13 across the board....all bolt-ons
