Pushrod Length Checker
Old Mar 29, 2006 | 10:33 AM
MICAH HERRON's Avatar
From: Johnsonville, SC; but orginally from GAINESVILLE, FL
Default Pushrod Length Checker
I just got one today and I am not exactly sure how to use it. Any help would be great!
Micah
Old Mar 29, 2006 | 11:14 AM
vettenuts's Avatar
I think I answered this on CF, did you post it there as well?
Old Mar 29, 2006 | 11:18 AM
Yes, thanks, I saw the post. I got the pushrod length checker from thunderracing and to be honest, I really didn't understand what you meant in the post on CF. I know this thing screws to different positions and was curious, do I put the checker in the head and then tighten it down checking if I have clearance or what. I just am not certain on how to use it and I really need to make sure my pushrods are correct.
Old Mar 29, 2006 | 11:42 AM
heavymetals's Avatar
You install the checker just like a pushrod and install the rocker, with the valve on the cam in the fully closed position.
You have to adjust the checker till you have NO PLAY.
That is 0 lash.
You may have to remove the rocker a couple of times to get it right unless you can screw the adjuster with the rocker installed.
Then carefully remove the checker, measure with a good caliper and add the length of the preload you want.
.025" is considered correct.
In other words, the length of the checker at 0 lash + .025".
Some lifters are more tolerant of more preload, but not much more.
RHOADS lifters are almost .060" of preload.
Old Mar 29, 2006 | 12:40 PM
SideStep's Avatar
Most here would shoot for .050 to .075... Tony (AFR) has a write up on it...
Old Mar 29, 2006 | 12:51 PM
my heads aren't milled, so I am hoping my stock lengths are good.
Old Mar 29, 2006 | 01:46 PM
TRYMYZ's Avatar
Could you post the link to that write up please?
Thanks
Old Mar 29, 2006 | 01:58 PM
Thanks
That would help out greatly!
Old Mar 29, 2006 | 02:09 PM
Viper's Avatar
"Most here would shoot for .050 to .075... Tony (AFR) has a write up on it..."
All depends on the lifter too:
Comp 850-16 OE replacement - .050-.075
Stock - .080-.120
Morel - .030
Comp R - .008-.010
Double check these numbers. don't use my list as the word ( except Morel, I'm 100% positive on that one )
Old Mar 29, 2006 | 04:24 PM
vettenuts's Avatar
Is that Morel number hot or cold? I was shooting for 0.040 figuring 0.010 of heat growth of the block/heads.
Old Mar 29, 2006 | 05:30 PM
Viper's Avatar
According to CStraub, cold.
Old Mar 29, 2006 | 10:10 PM
HavATampa's Avatar
Is the search feature broke again?
According to Tony from this thread - https://ls1tech.com/forums/generation-iii-internal-engine/455714-comp-xe-r-lobe-base-circle-vs-stock.html :
Assuming heads are in place with the proper headgasket (or the same thickness shims during mock-up), the following is a quick rundown to check and measure for proper pushrod length:
Install an adjustable PR initially set too small (makes sure cam is on the basecircle of the lobe you are checking)
Bolt down the factory rockers....
Set the adjustable pushrod to zero lash and remove
Measure pushrod, then add .050-.100 to that figure which now represents your pushrod preload into the lifter and the total length of the pushrod your engine requires. This is obviously quickie instructions for a factory rocker arm set-up (pedastal mount).
Old Apr 4, 2006 | 12:41 AM
01350ss's Avatar
are you supposed to torque the rocker down to 22ftlbs or finger tighten the rocker
Old Apr 4, 2006 | 05:26 AM
vettenuts's Avatar
Full torque isn't required as you don't need to preload the bolt. Just snug it up so there is no slop.
