Mahle Stroker Piston Quietness
Old Mar 30, 2006 | 11:41 AM
Steve Bryant's Avatar
LS1 Tech Veteran
Default Mahle Stroker Piston Quietness
I am planning to build a 408 iron block stroker and I am planning to use Mahle pistons (4.030" with -12 cc dish). These look to be good pistons for my daily driver, NA engine. However, they do not have offset piston pins so they will be subject to more rocking and possible piston slap during warm-up.
Does anyone have any experience with the Mahle pistons in a stroker. Are they quiet or do they have a noticeable slap during warm-up?
Thanks,
Steve
Old Mar 30, 2006 | 06:32 PM
LS1 Tech Veteran
TTT
There have been a fair number of lookers thus far. I could ask this same question of anyone with stroker and 4032 alloy pistons without offset pins. Another alternative that I'm seriously considering is a set of custom Wiseco 4032 pistons with offset pins. Please share your experiences if you have a stroker.
Thanks,
Steve
Old Apr 1, 2006 | 03:49 PM
LS1 Tech Veteran
TTT
Any thoughts?
Thanks,
Steve
Old Apr 1, 2006 | 06:16 PM
Camaro99SS's Avatar
They may be designed to fit tight enough in the bores so they won't rock when cold, yet not expand too much as to score the cylinder walls under high temps from boost or prolonged high rpm usage. just a guess though
Jason
Old Apr 1, 2006 | 07:03 PM
LS1 Tech Veteran
Thanks Jason,
You have the right idea. The design assembly clearance for this type of piston is about .003".
Steve
Old Apr 2, 2006 | 04:33 PM
Jason99T/A's Avatar
I can shift faster than you.
Steve, I"m running these in the 382ci motor that is my daily driver. Mahle calls for .0025-.003" clearance on their pistons for street application. The tighter clearance does help with piston slap on cold starts. I'm running mine a hair looser than that (.0040") since I have plans to spray this motor and the are still very quiet on cold starts, even with the pins not off-set.
These are awesome pistons for the price. I would highly recommend them.
Jason
Old Apr 2, 2006 | 07:15 PM
LS1 Tech Veteran
Jason,
Thanks very much. This is exactly the kind of information that I'm looking for! I have some piston slap currently with the stock pistons when cold for maybe 30 seconds, so I can live with some mild piston slap. I plan to run NA with piston to cylinder clearance of .003". I'll only be running 87 or 89 Octane.
Now, I have a related question. Ideally, I need an 18 cc dish volume with 72 cc combustion chambers with a .040 quench to get my target 9.6:1 CR. If I use the shelf -12 cc pistons, I could simply use a .060 gasket for the compression or I could have the pistons milled for 6 cc's more dish and run a more optimal gasket in the .040" range. I'm going to align hone the main bearing journals, set the deck heights at zero for the stroke/rod/piston length and then overbore/hone .030".
My gut tendency is to use the thicker gasket and forget the optimal quench due to cost and probably little gain for what I'm doing (daily driver/tow vehicle). I could also stay with the .040 gasket yielding 10:1 CR and retard the time a bit via EFILive. I could also set up dual switchable spark tables. I'm running a custom OS on my PCM now. I could add a switch and have a premium and a regular switch position. What is your opinion?
Thanks again,
Steve
Old Apr 2, 2006 | 07:20 PM
Camaro99SS's Avatar
Jason
I just watched your 1/4 mile run. Awesome run! Were those times with your 382 stroker or 347? Also, what were your shiftpoints? Also, how have the stock lifters and rockers held up to that wicked cam? I'm considering a setup just like this but maybe with a T-Rex cam.
Jason
Old Apr 2, 2006 | 08:31 PM
Mr. Luos's Avatar
I have these pistons in my 402.
Only has 500 miles on it, but I have not heard any piston slap...warm or cold.
Old Apr 2, 2006 | 09:17 PM
LS1 Tech Veteran
Mr. Luos, thank you sir!
Steve
Old Apr 3, 2006 | 10:26 AM
Camaro99SS's Avatar
Steve,
I would just use the shelf pistons with the .060" gasket and not worry about the minimal gains you could get if from flycutting the pistons exactly where you want them to get that quench. Since you're wanting to use 87 or maybe 89, it sounds to me like you're on a budget and aren't looking for exact, optimal performance for a given combo.
However, what I would do whichever route you take is run colder plugs to help with detonation and knock retard, especially since you plan on towing. You may have to change them a little more often, but your truck will be alot easier on the knuckles then an f-body. Obviously a 160 thermostat and conservative spark advance will be a must here as well. Essentially I would do what I could to stay out of detonation before having to richen up the air/fuel below the 12.9/1 range so gas mileage won't go totally down the drain.
I can't speak from experience here, so you may want to consult a notable engine builder or someone who's gone this route before, but I would think they'd recommend something similar.
Jason
Old Apr 3, 2006 | 12:09 PM
LS1 Tech Veteran
Thanks Jason!
Jason99T/A - What are your thoughts on this subject?
Thanks,
Steve
Old Apr 3, 2006 | 04:33 PM
Jason99T/A's Avatar
Jason
The 382 is in my daily driver (2000 WS6). The 347 is in the '99 Trans Am, which at the time was my daily driver. Not anymore though. I hardly put any miles on that setup, as it was strictly and R&D motor. It was tore down a few months later for a completely different setup. I have run similar lobes with stock rockers and lifters and had no issues to speak of. Shiftpoints were 7300rpms.
Originally Posted by Steve Bryant
Thanks Jason!
Thanks,
Steve
Steve, I'd personally run the .040" gasket, 10:1 compression, and you should be fine, especially with the dual spark tables. Have you figured out your DCR yet? What cam will you be running?
Jason
Old Apr 3, 2006 | 07:46 PM
TopFlite's Avatar
Subscribing...
Old Apr 3, 2006 | 08:01 PM
LS1 Tech Veteran
Jason (Jason99T/A),
My Dynamic Compression Ration is a 9.33:1 with my engine/cam combination. See attachments.
Steve
Attached Thumbnails Mahle Stroker Piston Quietness-dynosim-valve-timing-events.gif   Mahle Stroker Piston Quietness-dynamic-compression-ratio-calculation.gif
Old Apr 4, 2006 | 02:50 PM
LS1 Tech Veteran
TTT
Anyone have any more thoughts on this?
Steve
Old Apr 4, 2006 | 06:56 PM
gollum's Avatar
I would not line hone the block! If line honing is not done correctly you will need a shorter timing chain kit to take up the extra slack in the timing chain.
Old Apr 4, 2006 | 10:34 PM
LS1 Tech Veteran
I understand the warning on align honing of the mains. I have top notch shop that's going to do the machine work. Properly done, align honing is the basis of the other machining. The recent thread )https://ls1tech.com/forums/generation-iii-internal-engine/464633-there-any-0010-short-timing-chains-tensioners-available.html) on the block with the spun bearing is a warning to all.
Thanks,
Steve
