Lifter bering need help
Old Mar 30, 2006 | 03:27 PM
1blackz28's Avatar
Default Lifter bering need help
Ok put a new short block in last fall. Changed everything but the lifters. Yesterday when I was driving I noticed a slight ticking sound coming from the passenger side of the motor sounded like one valve ticking. Today I go to change the oil and there is about 10 lifter berings ( at least that is what i think they are), on the drain plug maginet. The car ran fine no power loss ect. What would be the chance that I messed up the lobe on the cam? I obviously will have to take the heads off and replace them. Will stock lifters be ok with a 224/224 .570/.570 lift cam from Thunder racing with the stiffer than stock springs that come with the kit?
Old Mar 30, 2006 | 03:58 PM
ROCNDAV's Avatar
check your rockers, they could be from a rocker.
Old Mar 30, 2006 | 04:04 PM
1blackz28's Avatar
You know what I didnt even think of that. What is the chance of them getting to the bottom of the oil if its from the rockers.
Old Mar 30, 2006 | 04:08 PM
ROCNDAV's Avatar
Very possible. Quite common, in fact.
Old Mar 30, 2006 | 04:22 PM
1blackz28's Avatar
Really are the oil drain passages big enough for thoes berings? And thanks for your help. You think I would have heard a louder noise if it was a lifter
Old Mar 30, 2006 | 04:59 PM
1blackz28's Avatar
Anyone elese have an opinion on this issue
Old Mar 30, 2006 | 05:55 PM
ROCNDAV's Avatar
I heard of valve locks working their way down there.
Old Mar 30, 2006 | 06:03 PM
1blackz28's Avatar
Wow then thoes could deffinetly get down there. once agian thanks for your help.
Old Mar 30, 2006 | 06:51 PM
ROCNDAV's Avatar
yeah, search the archives its been talked about on here many times. THe fix is to get aftermarket rockers, or better yet send your stockers (or buy used stockers off of ebay) to Nate @ Nasty Performance to do the Harland Sharp Mod ($250), which replaces the trunion with a better designed piece.
Old Mar 30, 2006 | 06:54 PM
chriswtx's Avatar
yeah, search the archives its been talked about on here many times. THe fix is to get aftermarket lifters, or better yet send your stockers (or buy userd stockers off of ebay) to Nate @ Nasty Performance to do the Harland Sharp Mod ($250), which replaces the trunion with a better designed piece
he means rockers not lifters. Its a common problem for the stock rocker to fail and leave bearings in the oil pan...
Old Mar 30, 2006 | 07:03 PM
1blackz28's Avatar
This makes me feel a lot better guys
Old Mar 30, 2006 | 07:08 PM
ROCNDAV's Avatar
oops, switch of the words there lol.
Old Mar 30, 2006 | 07:14 PM
1blackz28's Avatar
Yea I was like damn you just said you thought it wasnt lifters lol
