rocker issues
I assume they are Magnum 1.75?
Yea magnum 1.75 and yes theyre hitting the head, how do you clearance them?
But are you sure they aren't hiting the cover baffle?
theyre hitting that too....and where theyre hitting the head its already ground quite a bit of the wall down
*edit* I do believe Comp does make a non-adjustable rocker as well. Someone can chime in if I'm wrong. If they do make both adj. and non adj. you need to find out which ones you have.
