Spark plugs for heads/cam car?
I just put some tr6 plugs in..I need some good advice...I have a 1979 camaro..with 03 vette ls6..with dart pro heads..fuel injected..bigger injectors..not sure the exact size..previous owner installed those..and the dart pro 1 heads..as well as a pretty healthy cam..very nice lope .should I use these plugs? If so what should I gap them too? Or should I put tr55 s in? I ran the tr6 plugs up the road and back..with a .45 gap...they already completely black...what should I do? Smells of fuel...in my garage..really bad
i just threw a high compression 5.3 with a giant cam i spec'd for a stroker, and some decently worked over 5.3 heads w/ 2.02/1.57's. i have always run a tr5 gapped around .050 with absolutely no issues in any motor until now. This thing is eating tr5's. it appears to be too hot of a plug for the compression. I went back to a tr6 and haven't had an issue yet
Moderator
Received 1,851 Likes
Generally, TR6 is going to your generic go to plug for heads and cam upgrades. Various theories on where to gap it. On a HCI engine, 5's can cause detonation
