Spark plugs for heads/cam car?
With my heads/cam package in sig, I'm running over 11:1 compression.
Should I switch to a TR6 plug?
If so, what gap should I use?
No nitrous or other engine mods planned.
But.....
http://www.ngksparkplugs.com/techinf...00&country=US#
Higher Compression Ratios/Forced Induction will elevate spark plug tip and in-cylinder temperatures
Compression can be increased by performing any one of the following modifications:
a) reducing combustion chamber volume (i.e.: domed pistons, smaller chamber heads, mill ing heads, etc.)
b) adding forced induction (Nitrous, Turbocharging or Supercharging)
c) camshaft change
As compression increases, a colder heat range plug, higher fuel octane, and careful attention to igni-tion timing and air/fuel ratios are necessary. Failure to select a colder spark plug can lead to spark plug/engine damage
I can't be the first heads/cam guy to change plugs.
Yea, me too, I have often wondered if I needed to go 1 colder w/a h/c setup.
BTW, this advice came from patman, so kudos go to him.
However, in reviewing my spark plugs, the white portion is light pink. Not 100% sure what that means. This quote: "Today’s pump gas may use additives that cause a discoloration of the plug core nose; they could be pink, purple, or blue. Do not consider this coloration as an indication of heat range when reading spark plugs." from here: http://www.carcraft.com/techarticles/64378/ makes me not worry too much about the color.
Hello,
> >I would recommend the TR6IX stock no. 3689. This plug comes gapped to
.040. If you plan on opening it, go no more than to .050 and do so
carefully as it is a fine wire design center firing electrode and can be
broken.
> >Jon MacQuarrie
> >Motorsports and Events Coordinator
> >Aftermarket Division
> >NGK Spark Plugs (U.S.A.), Inc.
> >46929 Magellan Drive
> >Wixom, MI 48393
> >(248) 926-6313 Direct Dial
> >(248) 705-1485 Cell
> >(248) 926-6938 Fax
Kinda interesting, because it seems to be "contrary to popular belief" on this board.
Here, almost everything I've read (search feature) says to stick with the TR55s for heads/cam cars.
So, if it's true that the TR6 would be better, I'd consider that VERY helful info.
Has anyone here been using the TR6 on a heads/cam car and had a problem with them "fouling?"
I after reading several threads I have still to find an answer.
I have a head/Cam/intake/Exhasut car running 11:1 compression. I have both Tr5's and Tr6's.
Which plug should I run and what should I gap it to??
