comp cheater lobes
Old Apr 3, 2006 | 06:51 PM
algws6's Avatar
Default comp cheater lobes
has anyone used these lobes before?
lobes are 3404 and 3400.
.006 .05 .200 lift
285 232 147 580
289 236 151 580
112+4
Old Apr 3, 2006 | 10:56 PM
Beast96Z's Avatar
It can be done. I talked to Comp about having these lobes ground and they said they could do it on a LS1 journal. It would deffinatlly be something diffrent.
Old Apr 4, 2006 | 08:31 AM
algws6's Avatar
anyone else? supposedly these are big in the mustang classes that have to weigh at least 3000 lb and are limited on what lift they can run.
Old Apr 4, 2006 | 10:00 AM
blubird's Avatar
I am running these lobes. If you plan on using them you will need to flycut your pistons. They are very aggressive.
Old Apr 4, 2006 | 11:28 AM
algws6's Avatar
how do you figure they are less aggressive than the XER lobes. from what i understand duration determines your P/V clearance not the lobe profile. anyone else?
Old Apr 4, 2006 | 12:13 PM
cantdrv65's Avatar
Post
Take advertised duration - duration at .050 and you will see these lobes appear even MORE agressive than the LSK lobes! That being said Id expect this cam to make slightly more power than an XER but less than an LSK because the LSK offers a little more lift despite being slightly less agressive than this cheater lobe.
Old Apr 4, 2006 | 12:31 PM
algws6's Avatar
i thought the higher the number the less aggressive?
Old Apr 4, 2006 | 12:33 PM
blubird's Avatar
The advertised, .05 and .200 only tell part of the story. My cam is 232/236 580/580 113 icl 113 lsa, and I just pulled the heads of to discover that everyone of my pistons had a rather large semicircular divit in them. That's how I figure. Just because the LSK XER lobes have more lift doesn't mean they will make more power. Keep in mind most of the ported stock heads don't flow much more part .600 lift and some actually lose flow. So .580 lift isn't that bad.
Old Apr 4, 2006 | 12:44 PM
algws6's Avatar
where your heads milled any? what size valves where you using?
Old Apr 4, 2006 | 01:02 PM
blubird's Avatar
Heads were 5.3s w/ 2.02 intake valves milled .01. You might be able to get away with a stock head but from my experience I wouldn't try.
Old Apr 4, 2006 | 01:15 PM
Patrick G's Avatar
LS1 Tech Administrator
.006 .05 .200 lift
285 232 147 580
289 236 151 580
112+4
Those Cheater lobes are much less aggressive than XE-R lobes or LSK lobes.
Using your example:
.006 .05 .200 lift
285 232 147 580 Cheater lobe
289 236 151 580 Cheater lobe
281 232 153 595 XE-R lobe
285 236 157 602 XE-R lobe
281 231 156 643 LSK lobe
285 235 160 646 LSK lobe
The aggressiveness of a lobe has to do with how fast the lifter gets off the cam base circle and into lift. The rate of lift from .006 to .050" is 53 degrees for Cheater, 49 degrees for XE-R and 50 for the LSK. The XE-R has the most aggressive ramp from .006 to .050", but the power is made after .050"...this is where the LSK lobes spank the other two lobes.
From .050 to .200", the Cheater is 85 degrees, the XE-R is 79 degrees and the LSK is 75 degrees. Basically that means the LSK lobe will give you 10 degrees more duration at .200" than the Cheater lobe with the same duration at .050" and less advertised duration. IMO, the Cheater lobes are weak. If they were the best, you'd see more people running them in LS1s.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Apr 4, 2006 | 02:30 PM
algws6's Avatar
patrick, do you know of anyone that has tried them? blu, what kind of numbers did you put down and what kind of times where you running? what were your supporting mods?
Old Apr 4, 2006 | 04:23 PM
algws6's Avatar
i thought you had plenty of room.
https://ls1tech.com/forums/dynamometer-results-comparisons/451880-01-camaro-h-c-dyno-numbers.html
did you hit on the intake or exhaust?
Old Apr 5, 2006 | 12:16 AM
blubird's Avatar
I had no indication of PTV issues until I pulled the heads a couple of weeks ago. I never got any track results due various issues. I had trans problems followed by clutch problems followed by a spun rod bearing. I did notice when I pulled the intake off it appeared that #7 cylinder was not firing. All the intake ports except #7 had carbon deposits lining the port walls. #7 was completely clean. So who knows maybe once I get everything straightened out it will be respectable again.
Old Apr 5, 2006 | 02:21 PM
cantdrv65's Avatar
Post
Yep as patrick pointed out I had it backwards.
Old Apr 5, 2006 | 05:16 PM
Beast96Z's Avatar
The cheaters a just a bit more harsh than the XE lobes. If someone was wanting something similar to a XE profile, but wanted the extra lift, this would be a good choice.
Old Apr 5, 2006 | 07:28 PM
algws6's Avatar
why does it state "race only" in the comp catolog?
Old Apr 5, 2006 | 07:32 PM
Patrick G's Avatar
So maybe the uneducated will buy it!
Old Apr 5, 2006 | 08:07 PM
algws6's Avatar
patrick, have you actually seen these lobes in action or are you just speculating?
Old Apr 5, 2006 | 08:23 PM
Patrick G's Avatar
Haven't seen them in action, but based on their specs, I'd say they'd be be between XE and XE-R lobes. Since most people are running XE-R lobes, I'd say it would be taking a step down.
