Does Anyone have a GM Hot Cam?
Old Apr 7, 2006 | 02:11 AM
BigDaddyBry's Avatar
Ha ha, is there an echo in here???
Originally Posted by BigDaddyBry
I agree that if you stick a TR224 in the same car, but there are soooooo many other factors, that you can't consider cam alone.
Originally Posted by GuitsBoy
All things being equal, i could easily see a 224 making more power. I mean, after all thats the only way to compare one cam to another..
Old Apr 7, 2006 | 07:34 AM
GuitsBoy's Avatar
What Im questioning is why you would consider more than just the cam? Of course the car with the better supporting mods is going to put down more power. I just dont follow your logic on comparing cars.
Old Apr 7, 2006 | 11:03 AM
I didn't say anything about comparing different cars, read it again.
I said SAME car, because you don't change more than one variable (the cam). By doing the comparison on the same vehicle, you can compare the performance of two cams with a given set of mods.
In other words, the car and it's mods don't change, only the cam.
You sounded like you said the same thing ("echo").
Old Apr 7, 2006 | 11:18 AM
GuitsBoy's Avatar
Now that's BS. Check out the dyno section, it's not always cut and dry.
I agree that if you stick a TR224 in the same car, but there are soooooo many other factors, that you can't consider cam-alone.
Youre saying one thing and then now youre saying the complete opposite.
If you want to compare cams, dont change any other variables. That means use the same car with the same mods. Its as simple as that.
Old Apr 7, 2006 | 11:28 AM
TTU98SS's Avatar
WERD. IM saying if you take the hotcam out and put the 224 or 228 etc. etc. in the SAME car, I would put every dime I have on the fact that the 224 or 228 will make more power.
Old Apr 7, 2006 | 12:01 PM
Which is EXACTLY what I said.
Your original quote sounded like you were comparing different cars. My mistake for misunderstanding you.
i call BS. someone with a 228 grind or TR224 will make more power than the hotcam 99 times out of 100. hotcam is crap go bigger
Old Apr 7, 2006 | 12:02 PM
Right, read what I wrote:
"I agree that if you stick a TR224 in the same car"
How hard is it to understand "same". Here's some help:
same
adj.
Being the very one; identical: the same boat we rented before.
Similar in kind, quality, quantity, or degree.
Conforming in every detail: according to the same rules as before.
Being the one previously mentioned or indicated; aforesaid.
Someone or something identical with another.
Someone or something previously mentioned or described.
Old Apr 7, 2006 | 12:06 PM
Sound familiar??? Wonder where you got your wording from:
Old Apr 7, 2006 | 12:31 PM
Cali SS's Avatar
True 224 will make more power, although not much more than the hot cam. All I know is I've never been "walked" by a 224 cammed car. All of the races were close. I'm satisfied with the numbers I've put down with the hot cam. They are similar numbers to 224 cams.
My dyno results:
Old Apr 7, 2006 | 06:34 PM
mcflyz28's Avatar
Ditto what he said , do the 22x cams make more power on the DYNO yes if they are tuned and some even untuned, I said they don't walk on me, I don't do any racing on a dyno the damn straps hold me back, the dyno guys are always the ones with the excuses when they get beat either on the street or the track, it takes alot bigger cammed car than a 22x to walk me and checking my valvesprings never enters my mind.
Old Apr 7, 2006 | 07:30 PM
spazzyfry123's Avatar
Freak out!
Old Apr 10, 2006 | 05:43 PM
  #32
I hear ya mcfly.
