Please post your cam specs w/patriot ls6 heads!
I'm wanting to put a big cam in a 346 without fly cutting.
I have Patriot ls6 style heads 62cc chambers 2.055 1.60 valves.
What cams are you running, and what are your cyl head specs?
Thanks
Thanks
Originally Posted by Xtnct00WS6
LS6 style or 243's? Are they milled at all? Flycutting? PR length?
Just curious
Just curious
I have unmilled 59cc 2.055" I LS6 style PP heads with the TSP 231/237 .598/.595 112 cam, but have JE pistons with reliefs. They should clear stock pistons just fine though.
Originally Posted by GENIII
Patriots II 64cc with a Comp 244/248-609/615, block decked 0.022
Opps I just read your sig. you got dished pistons.
Previous- Patriot LS6 heads, 2.02/1.57 valves, with a Futral F13
Now- Patriot stage III LS6 heads, 2.08/1.60 valves, with a comp 244/248 .612/.615 113lsa
Did a H/C a couple weeks back for a guy: Patriot stage II LS6 heads, 2.02/1.57 valves with a TSP 231/237 .598/595 112lsa. This seems to be a pretty common setup. Its stought to.
Originally Posted by N20SS
From what I see here, the 235 240 600 609 111.5 should clear fine. I wonder why TSP said no. I really don't want to pull the heads, but I don't want to bend valves either.
