Iron block main bearing clearance ..
Old Apr 4, 2006 | 10:58 PM
Flyer's Avatar
Default Iron block main bearing clearance ..
measured out at .0015.
Good? Bad?
Old Apr 4, 2006 | 11:04 PM
Jason99T/A's Avatar
I can shift faster than you.
That is too tight for an iron block application. For street/strip applications, I shoot for .0024-.0026", with the on the thrust on the looser end of the spec.
I have run them as tight as .0020" on iron blocks with no problems or exessive bearing wear. Just be careful with your oil temps though.
Jason
Old Apr 5, 2006 | 07:39 AM
Flyer's Avatar
What should I do then?
Have 5 tenths taken off?
Old Apr 5, 2006 | 08:43 AM
kossuth's Avatar
go with a +.001 oversize bearing if you don't want to have the crank polished up. If you have the crank polished it might come down to .002 or so. Federal Mogal makes a set of .001 +- bearings I think for STD STD.
