Installing cam and it think if am Fu#@$
Old Apr 9, 2006 | 11:56 PM
Joel_SS's Avatar
Default Installing cam and it think if am Fu#@$
In the process of in stalling a cam in my 99 A4 I went to take the starter out and the long starter bolt broke off in the block as I went to break it loose. Has anyone ever done this and had success in drilling it out?
Old Apr 10, 2006 | 12:24 AM
Ian300D's Avatar
Small drill and a easy out should do the trick.
Old Apr 10, 2006 | 12:38 AM
SLP4CamaroSS's Avatar
at sears they got drill outs for liek $19.99 come in a pack of 3
Old Apr 10, 2006 | 02:45 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Easy outs can be a pain in the ***...Tell me this isnt your new shortblock Joel!
Old Apr 10, 2006 | 09:43 AM
Joel_SS's Avatar
No it is not..
Thanks for the advice all I will try the easy out..
Old Apr 10, 2006 | 10:21 AM
REDWS6ROCKET's Avatar
starter bolts are very tight, best bet is to start out small and work your way up to the correct size. need to find a tap and the drill bit the tap calls for.
Old Apr 10, 2006 | 12:03 PM
Joel_SS's Avatar
Yes the botls were VERY tight. What material are they made out of?
Old Apr 10, 2006 | 12:37 PM
Taspeed's Avatar
they aren't hardened if that is what your after. Be sure when you drill it get it DEAD center or you will have trouble getting it out.
Old Apr 10, 2006 | 12:56 PM
Joel_SS's Avatar
Good I was hoping they were not hardened.. Any idea what size I need?
Old Apr 17, 2006 | 04:47 PM
Joel_SS's Avatar
All, I used a drill bit to drill a hole right down the center, and the shoved a bolt extractor up in the newly drilled hole and the slug came right out smooth as butter.. Thanks for the advice all!!
Old Apr 17, 2006 | 05:26 PM
Rescue Ranger's Avatar
woo nice man grats on the fix.
Old Apr 17, 2006 | 05:51 PM
Joel_SS's Avatar
Thanks !! That was a monkey off my back.. I just felt sick when it happened!
Old Apr 17, 2006 | 06:28 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Glad you got it fixed! Now what is wrong with the bird?
Old Apr 17, 2006 | 07:47 PM
Quik's Avatar
why the hell are you taking starter off to do a cam ?
Old Apr 17, 2006 | 08:02 PM
onebadz's Avatar
On A4's you have to lock the flywheel to get the crank bolt out and stop the motor from turning. You cant just put it in gear like in M6's.
Old Apr 17, 2006 | 08:10 PM
VORTECFCAR's Avatar
I didn't take the starter off to do mine...
However, I don't think I have a whole lot of credit right now on this board (just finished first H/C swap). If my car doesnt eat itself within the next month I'll post the cheat.
Old Apr 17, 2006 | 08:22 PM
Quik's Avatar
i understand that and still wonderd that. on my trans i have a little plug that comes out on the bell housing that i just insert a pry bar to stock it from spining over
Old Apr 17, 2006 | 09:17 PM
Joel_SS's Avatar
I removed the starter casue that is what the cam install guide from ls1howto.com says to do..
Old Apr 17, 2006 | 11:29 PM
SUX2BU's Avatar
I just impact that bitch off.
Old Apr 18, 2006 | 01:10 PM
30birdy's Avatar
Nothing now... I hope
I'll know more on Friday Denton
