What times to expect with this CAM
However, the guy selling me the heads told me this might kill my low end torque completely. Any thoughts on this?
Once again...here is some great info from very knowledgeable guy
I was originally paying Patriot $xxx to clean the heads and fix anything that might be wrong with it, mill the deck surface to make it true, and install Patriot dual springs.
He told me if I wanted the larger valves he could put them in for the same amount.
Would you still leave the stock ones in it or should I go this route?
Also, with the larger valves will there be enough PV clearance for the 228 .595 112lsa cam on an Xer lobe?
Thanks!
