Ticking, Need Help!
Old Apr 18, 2006 | 12:16 PM
nokeman's Avatar
Could just be regular old piston slap...
Old Apr 18, 2006 | 02:57 PM
01pewterbird's Avatar
same here Justin had some good WOT spurts then heard I that night, def not normal piston slap if it continues while warmed up
Old Apr 18, 2006 | 04:45 PM
outkast6991's Avatar
mine started after my cam swap.it is loudest when listening at the bottom of the driver side fender.with the hood open you can barely here it.i changed the oil to 15w50 to see if it would quiet it down,but no luck.back to 10w30 now.also checked for exhaust leaks,plug wires,and plugs.no luck.if you guys figure it out let me know.i'm thinking a bad lifter
Old Apr 18, 2006 | 05:48 PM
Viper's Avatar
Mine does the same as the post above. And, it's happened through TWO motors! So I don't worry about it, my thoughts are valve train noises from an aluminum block through stainless steel headers. Car runs fine.
Old Apr 18, 2006 | 08:58 PM
Viper, did your motors always make the noise, or just start one day?
Old Apr 18, 2006 | 09:01 PM
Viper's Avatar
Since the first startup on the motors. After reading all these posts about it, the only other thought is what was kept with each motor: idler pulley. TO bearings been replaced with every clutch swap (4 ). Have a UD pulley now. I just noticed you have SW headers too, although I know they work very well.
Old Apr 18, 2006 | 09:50 PM
1QWIKBIRD's Avatar
I'd just pull the valve covers and make sure a rocker didn't spew the needle bearings, that's what mine sounded like when it happened....and it still pulled hard and started and ran fine, but I'm sure full scale carnage wasn't far off had I not pulled the valve covers......do it if only for piece of mind.
check this link for info on rocker arms failing....
https://ls1tech.com/forums/generation-iii-internal-engine/490054-rocker-arm-bearings-broke-off.html
Chris
Old Apr 18, 2006 | 09:55 PM
How do i know if it has lost the needle bearings, What would be a visible sign on the rocker?
Old Apr 18, 2006 | 09:59 PM
rubber duck's Avatar
if it's after a cam swap and you kept your stock pushrods it's probably valvetrain noise as long as it's a tick and not a knock. I'd pull the covers for peace of mind though.
Old Apr 19, 2006 | 09:22 AM
TheBlurLS1's Avatar
That's what she said...
Mine does the same thing, can't hear it under the hood, but its loud beside the car, especially if you drive by something.
It drives me completly insane.
Old Apr 19, 2006 | 11:53 AM
01formula6's Avatar
If someone figures this out let me know. I have the exact same symptoms. Can't hear it under the hood, standing on the drivers side it's kinda loud. Annoys the hell outta me. It started when I put the headers on. Car runs fine, just makes a ticking sound.
Old Apr 19, 2006 | 12:26 PM
  #32
Formula make sure you check your plugs and header bolts, some could be loose. I had a loose spark plug and it sounded similar to this.
Old Apr 19, 2006 | 01:31 PM
  #33
nokeman's Avatar
Haha this problem is a lot more common than I though.
Old Apr 19, 2006 | 01:58 PM
  #34
TheBlurLS1's Avatar
Welcome to LS1tick.com!
Old Apr 19, 2006 | 02:06 PM
  #35
nokeman's Avatar
Hahaha!!
Old Apr 19, 2006 | 02:12 PM
  #36
01formula6's Avatar
I've checked the header bolts and they are all tight. I was just going to check the plugs in a week or so when I do my cam swap. I'm positive they were all tight when I installed them, unless one has loosened up. If it's a loose plug I'm going to give myself a good
Old Apr 19, 2006 | 02:23 PM
  #37
Formula i've been there done that, pulled the valve covers because of the tick and everything was fine in there, and THEN i check the plugs realizing that could be a problem and sure enough it was oh well live and you learn
Old Apr 19, 2006 | 02:26 PM
  #38
nokeman's Avatar
Plugs can come undone every once and awhile. From what I understand, MSD superconductir ires, which I have, tend to come off more often. I just check to see if mine are tightened down once every two weeks or so. One thing I havent check yet is if my header bolts are tightnened down but I couldnt imagine they would have come loose. I have never even toughed the headers since ive owned the car. Im starteing to get a little worried though cause there have been case of lifters going bad or starting to go bad and I really dont want that to happen.
Old Apr 19, 2006 | 02:32 PM
  #39
Nokeman i'm really hoping myself it isn't a lifter. Although to me, when i think about it, since the sound comes from down below more then up top and it isn't a plug it really gets me worried learning towards thinking it is a lifter, once i get home from school today i'm pulling the valve cover to check on the needle bearings, following it with an oil change, then i'll fire it up again and see what i got.
Old Apr 19, 2006 | 02:37 PM
  #40
nokeman's Avatar
Well wouldnt a lifter be heard more from up top than down from below? I could just be mistaken...
