Will a 110 LSA fit...?
Refer to my post here for more information on DCR and ICL. LSA is part of it, but the ICL in relation to the LSA is what determines the valve events and DCR, and thus why such an understanding of the two is vital to proper camshaft selection. Also overlap is what determine ultimate power and idle--large cams on a 112 with more overlap than a smaller cam on a 108 will idle shittier. Of course, raising or lowering the idle RPM will affect the idle quality just the same.
Personally, I think the 234/238 110+1 (not +2) Comp XE-R is a great grind. But it may be best suited to AFR 205s. The high velocity heads allow a slightly larger grind, and the valve events of the 234/238 on a 109 ICL are balanced near perfectly to what Tony always recommends for the AFR heads.
Btw, Patrick, the FAST 90 has some limiting effects--but in talking with tuners that build mega strokers (441+) for Vettes, they are pushing 580-600rwhp with LS6 heads and a FAST 90 in M6s and 550rwhp+ on A4s. I think a lot of power could be realized from a better intake that is tuned more appropriately; but even on jinormous engines, it still peaks around ~6300. I find that interesting.
It is my opinion and my opinion only to not get to crazy when trying to come up with a cam grind for a basically stock motor. There is no clear answer to these questions when it comes to camshaft selection which is stated in the FAQ.
Its simply amazing to me how much goes into cams and these engines and all. It just blows my ming! I hope people put a lot of research into selecting thier cam because after this an some other threads, theres much more that goes into it than just lift, LSA, etc. Thanks for all the info guys!
. By the way is that even possible or has anyone ever tried putting a 572 in a camaro or firebird? That would just be nuts!
