People with the G5X3
I'll post here after the Dyno tune, install is going well. Checkin valve clearance with the .05's to see if I can mill any.
Thats cool.. What size gasket are you planning to run?
Im going to do a pre-dyno run and see what she is stock wise. Then add the G5X3 cam, Stage II darts, 90/90 set up with all the little goodies just to see what I gained. Hopefully, i will have it all done come mid May.
Hopefully in the future when I get the vette I want Ill get to pu this cam in it. Thanks for all the input though. Hope the people putting it in have a good experience with it.
I'm going to check valve clearance with stock gaskets and if I have room was thinking about .40 cometics. Instead of milling, as I don't think there will be much room for more than this. just ordered a new mandrel and cartridge rolls to do a real light clean up in exhaust ports.(casting flash) and a little spit shine using 120 grit and then 240 tapered rolls.
cleanup.http://www.ruffstuff.com/
Cylinder Head Abrasives
John
if G5x4 = "around town just as nice"
then why not G5x4 > G5x3 ???
making me think i gotta get an x4 in my daily
John
Im "hoping" that with the .040"gasket and the ~62cc dart head, and the X3 cam will not have any PTV issues. That would make the install soo much more easier.
Keep us updated as I will do the same.
John
dont be a ****!
youve got SIX GEARS, buddy..
i only have four and im thinking about 4.10s
you can do 78MPH @ 2100RPM with 4.10s!
how great is that?
im willing to bet going 4.10 would even make sixth gear more useful..
http://www.f-body.org/gears/
how great is that?
Well really was 395rwhp with mine (still was pissed) plus I had very good tuners mess with my car, 3 of them in fact, all they could muster was that. My friend with the 01 Z06 could only get 412rwhp with bolt ons. Wish I would have gone with the TRex, next cam is the RPM-5. Works good on spray tho
Mr. Deex99 flycutting is notching the pistons to make more clearance between them and the valves so they don't hit each other.
Another question for this thread,
Will the G5X4 work with the PRC CNC LS6 heads from TSP? The heads have stock valves so I imagine it would-I've heard they work with the TRex.
Also, did anyone figure out if the G5X3 and G5X4 will work with the out of box Dart 205s and 225s?
I have heard that on the X3 cam WILL fit (with a stock gasket) down to a 59CC head or an untouched head for that matter. But, I dont know up to what valve size with an aftermarket head. So, I think the 205's are ~62cc so it ought to work and give you some room with a stock gasket. I went with a .040" gasket, so I hope it works.
Prostock idle is killer!!!!You will need a good tuner,mine still needs some tweakin.
