Is this cam worth the install
Old Apr 20, 2006 | 10:37 AM
Ramshaft's Avatar
Default Is this cam worth the install
one of my buddys has a cam that he is willing to sell to me for 100 bucks. i am just wondering if it is going to be worth the hassel of installing it and spending the money to get it. ie how much power can i expect to gain what kind of driability issue would i have for a dally driver. and info would be great.
here are the specs:
Duration at .050 Intake 228 Exhaust 232
Lobe Lift Intake .3460 Exhaust .3380
Lobe separtatoin 114.0
my mods are in my sig and i just put a 100 dry shot on this weekend. if you need any other info i have the cam card just let me know. I really appriciate any help i can get. can afford to waist any money i don't have much so i have to strech it pretty thin so i can go fast
Old Apr 20, 2006 | 10:44 AM
99camarosupersport's Avatar
i'd say that camshaft would respond pretty well to nitrous, besides it's better than stock right? also an ls6 intake wouldn't hurt either in your near future.
Old Apr 20, 2006 | 10:52 AM
ringram's Avatar
Yep, go for it, that looks like it will be nice.
Old Apr 20, 2006 | 11:00 AM
Ramshaft's Avatar
so does any have any ideas on what kind of power gain i would have?
Old Apr 20, 2006 | 11:14 AM
nokeman's Avatar
I would say defintely worth it. Thats a decent size and will like nitrous.
Old Apr 20, 2006 | 12:06 PM
HOSS's Avatar
any cam likes nitrous if you think about it..lol
Old Apr 20, 2006 | 01:37 PM
mike c.'s Avatar
that cam should pick you up 20-25hp over stock and the spray will love it too.
Old Apr 20, 2006 | 05:52 PM
Ramshaft's Avatar
hey thanks every one for there input. I know i can change it my self but i just don't know much about the actual grinds and all that stuff.
Old Apr 20, 2006 | 09:06 PM
Ramshaft's Avatar
what all would i have to change if i got this new cam. i have stock heads on there and don't want to get new heads right now, way to much for my budget. just looking for what else i would need to do the install thanks for the help
Old Apr 20, 2006 | 10:04 PM
kyles2000z's Avatar
dont forget new springs ans pushrods. thas a decent size cam and wouls def. be worth the install.
Old Apr 20, 2006 | 10:40 PM
i'd get PRC dual springs for safety, obviously new hardened pushrods, gaskets, timing chain and ported ls6 oil pump wouldn't hurt ya either, just to be safe, better to be safe now than really sorry and broke with no car later
Old Apr 21, 2006 | 06:15 AM
b1er's Avatar
That looks like the same cam I have..... .588 .574 228 232 114
you'll love the idle...and I didn't see headers in your sig but they'll help too when you can swing them....
you will need tuning.....and you'll likely max your injectors or be really close....mine (stock 26'ers) were at 112 DC at 6300 rpm
here's my whole set-up for comparison:
99 TA A4
hand ported 241 heads (not much gain)
above cam
LS1 intake
38lb svo injectors
Walbro 255L pump
NOS 100 dry
Lid
Pacesetter LT's & ORY & cutout
TCI SSF3500 stall
3.23 gears
3730 raceweight
I went 11.65 @ 118.xx so far spinning my ET streets to a 1.75 60'....best 60' is a 1.65 with a stone stock suspension....hoping a new set of ET drags will hook to around a 1.60 maybe a high 1.5....
Good luck with the cam....I think you'll enjoy it in an M6....
Old Apr 21, 2006 | 11:39 AM
Ramshaft's Avatar
i am looking at get headers soon, a friend of mine say he can get some really cheap for one of his friends so we will see how that works. but i want to say thanks to every one that has posted, got some really good feed back and i am going to get the cam probadly next month
Old Apr 21, 2006 | 09:35 PM
if your friend can't get you the long tubes, look into uncoated pacesetters they will last 10 yrs or so and only are 2xx dollars.
Old Apr 22, 2006 | 12:35 AM
Ramshaft's Avatar
yeah that is what i was looking at before he told me he could get me some. but thanks for the heads up
Old Apr 23, 2006 | 12:50 PM
Ramshaft's Avatar
so what are the best springs and push rods for this set up. and where can i find them cheap. i when to the strip friday and was very disappointed best i could manage was a 8.9 with a 2.33 60' but i was getting really really bad launches. i just need to see how much i am going to have to spend in extras so that i can install this cam. got to work the budget(wife) so i can swing the cam and stuff to install it.
Old Apr 23, 2006 | 12:57 PM
98Z28MASS's Avatar
That cam shaft, with all the bolt ons, should put you near 375-380 rwhp (with a good dyno tune). It should also respond well with that 100 shot and on N20 should put you near 500 rwhp, whihc would be sick on the street and the track. Id say with that cam to go with a minimum of comp 918 valve springs and some hardened pushrods. In addition id say go with an ls2 timing chanin to replace the stocker. That should be good for the valvetrain though. Might also want to look into some bigger injectors if your going to be running that cam and a 100 shot. Good luck though and sounds like a stout combo!
Old Apr 23, 2006 | 12:59 PM
98Z28MASS's Avatar
Id check texas speed or byunspeed for the valvetrain components as both give great prices and service, and I know byunspeed will meet and beat just about any price out there.
Old Apr 23, 2006 | 01:17 PM
Ramshaft's Avatar
awsome thanks
Old Apr 23, 2006 | 04:13 PM
b1er's Avatar
918 springs
7.425 pushrods.......I did the math and these are what mine needs (I run stockers now) I have a bit of valve train noise with them...not too bad though
LS2 timing chain (cheap)
LS6 oil pump (might as well since your there anyway)...look for a low milage one on the forums here...cheap
Cam change gasket set....
At least 36lb injectors....for the spray and cam and the future...I run 38lbers....
You will need tuning.....my car wouldn't even start up on the stock tune...YMMV
You may also want to upgrade the rod bolts at some point so you can spin the motor a bit higher as that cam likes rpm....I shift at 6300 and limit mine to 6700 on the stock bolts....
My car hasn't been on a dyno but doing the math from the trap speed and raceweight it puts down around 400 to the tires NA and about 500ish on the 100 shot....
your car will only get better as you add stuff like headers, and stuff...
