T-REX vs. MS3 on the track.
Just look at the cam-only ET records and see what cams dominate the top. Either T-Rex's or T-Rex clones (like LS1 Joe's).
If you had similar setups as far as converter, gearing, boltons, etc; I think the result would be too close to call. Both cams produce great numbers at the track. I daily drive my MS3 and driveability is great, but it is all in who tunes it. Bottom line is they are both great cams, and you can't go wrong with either.
https://ls1tech.com/forums/drag-racing-results/187330-fastest-cam-only-cars-list.html
Smokin01ta ---- 10.219@132.29 (1.38), 01 TA, M6, Spec4, 4.56, TRex, -1100, 3010, 3/06
Trevor @ TSP --10.510@125.80 (1.43), 98 Z, A4, TCI 4500, 4.56, MS3, -1000, 3175, 2/05
Rodney is 165lbs lighter, and has a M6 with 4.56s whereas Trevor has a A4 with 4.56s. Rodney comes out of the whole a lot harder, and MPH more. I think if you put a MS3 in Rodney's car, it would go 10.25-10.30.
I would like to add that that was one of 3 ever cam-only passes ever made in that car. We weren't as dedicated to cam-only as some have been, we didn't even know what it would run before that date. I would have liked to pull some more weight out of it and setup the suspension properly, there just wasn't the time nor care to do it right. Shortly afterwards we put a 200 shot on it and melted most of the shortblock anyway, lol.
Now that the car has a good fuel system and FAST XFI, we're thinking of doing a mild turbo setup, or possibly another Solid Roller motor, probably a 370ci setup either way.
I think either setup will get the user where he/she wants to be, as long as the combination is optimized for each cam.
It was just a joke buddy
I have a dinky cam compared to that monster (not to mention its on a 110 lsa with ungody lift.) Mine is respectably loud (I have the whole nascar thing going) but it isnt anything to go whoa about. Now this summer......MS3 goes in along with a 150 shot and we'll see how it sounds.
