T-REX vs. MS3 on the track.
EDIT... i dont know what kind of intake works best with boost app... if its an ls6, keep your ls6 and use the ms3... the ls6 is almost enough intake for it...
if you have the extra money go with the FAST though.. then do what you have to later..
the difference between an ms4/4.56 gear and trex/4.56 gear would be driver. assuming other things are equal. weight, supporting mods, etc.
lemons is right. proper matching is the biggest thing.
right on... if you look a little bit after what he quoted, i gave my theory... and i believe it to be correct...
another difference between the 456/ms4 and 456/trex is the ms4 is going to be easier tuned and more streetable..
sorry... i had to.. anyways..
why are you set on the trex? (im trying to get to what you want out of the car and why you chose that over "X" cam..
how much money do you have to build your project..
DD? street warrior?
we need a LOT more info..
, I talked with TSP yesterday and they said the MS3 or a custom cam would be my best bet
