Why the 5.3 head?
Reason 1: 5.3 heads will raise your compression and if you ever decide to go with a turbo, supercharger or nitrous then the added compression will hurt you.
Reason 2: With 5.3 heads you can't go with as large cam as with LS1 or LS6 heads.
If you don't mind needing higher octane gas, you plan a moderate size cam and don't ever plan on going bigger then 5.3 heads could work. Just don't go with the Patriots. They caused me a lot of problems. With in 2 years, three valves went bad and I had to spend a lot of money fixing them. Plus my horse power increase was little to none until I paid the money to have them redone.
The added compression will give you about 5 extra horse power than the LS1 heads. Also if you do, go with 5.3 heads get at least stage 2 heads with 2.02 and 1.57 valves.
My choise if I had it to do over would be the new Dart heads with 225 runners and 2.05 and 1.6 valves. Also my cam would be much larger than the one I chose.
Best of luck,
Al
Best of luck,
Al
1- Even ported they are 215>220 cfm int ports which promotes velocity.
2- They raise compression while keeping stock PTV.
3- You can recess the valves to increase PTV with bigger valves.
4- Cost efficient (that is untill the LS2 casting came along)
5- Ported properly, they are capable of over 300 cfm flow (with small ports).
Yes the LS6 casting is better, but was too expensive until the LS2 casting came along in 2005. (both are 243's but with different valves)
Nowadays that is the budget casting of choice.
I will be using these heads again.
It really depends on the valve events.
I know that a 112+4 will not fit mine.
Good to see you around again Sheets.
FYI a 233/239 113+0 will also fit with recessed valves
Thickness of valve seats has to be acounted for, some valves eat as much as .020 PTV due to their seat thickness.
give this man a drink,
just goes to show you don't believe everything online. I strongly agree, no2 loves compression. Avise, call some professionals and get some ideas, plan ahead, do research here as MOST are knowledgeable, but you can easily get incorrect information as well, heads are a big decision put a good amount of thought into it. Call MTI, TSP and Thunder, get their recommendations, then bounce it off here, this way you can get the best fit for your own plans and future mods.
Pedator z has got great info here.
FYI, I did limit my intakes to 2.02" to work with the F14 (232*/234* .599"/.600") cam. I'm running at 4,800ft above sea level and I need the bump in compression the 862 castings offer.
PredatorZ check THIS out. We didn't do alot to the chambers, but I'm under the understanding there's not alot to be gained there. The valves were recessed and the ports flowed and matched. Chambers came out right at 62cc.
The guy that did the work ran them on the bench compared to a stock LS1 head and was very happy with theimprovement in flow under .600" He was working hard to maintain good flow under the curve and not just peak numbers.
I won't know the full results until I get it all together and start dyno tuning.
You see alot of people milling 241 casting .030" to get compression up. The reality is a 5.3 head is basically a 5.7 head with a .030" lower combustion chamber. So you get the CR bump without the valvetrain geometry re-alignment of .030" Either way will work. It's all about budget, availablity and your long term goals.
That is with .053/54/55 gasket.
eventually....
