high rev kit
Old Apr 21, 2006 | 11:42 PM
Rob@EFIAlchemy's Avatar
LS1Tech Sponsor
Default high rev kit
anybody know who makes an ls1 high rev kit and if there any good?
Old Apr 22, 2006 | 09:24 AM
BrandonDrecksage's Avatar
there is different heads, cam packages that make power at different levels. What do you mean by high rev?
Old Apr 22, 2006 | 10:26 AM
Gearhead1's Avatar
This will explain it better than I ever could. They go in the lifter valley between the cyl head and the lifter and actually provide extra spring pressure on the lifter to help it maintain contact with the cam.
http://www.compcams.com/technical/Ca...106-07/279.pdf
Old Apr 22, 2006 | 11:41 AM
92zcamaroperson's Avatar
I would think that those would only be neccessary on really high revving engines. >7k rpm
Old Apr 22, 2006 | 12:55 PM
HOSS's Avatar
you don't want to rev the stock cam high, there is no point.
Old Apr 22, 2006 | 01:17 PM
mpe488's Avatar
I agree. Just make sure you know what you're doing. Don't think your LS1 is going to put out twice as much hp as tq if you rev it to 8,000 like an import would. If you're gonna rev higher you'll need a bigger cam to actually make power in those rpms.
Old Apr 22, 2006 | 09:12 PM
Lasershop's Avatar
Shameful.... I know... But he asked.
https://ls1tech.com/forums/generation-iii-internal-engine/314359-custom-rev-kit.html
Old Apr 23, 2006 | 01:36 AM
BOWTIE's Avatar
https://ls1tech.com/forums/showthread.php?t=314359
Those are sweet looking... I know ARE (Agostino Racing Engines) used to produce a set of these for the LS1's, but since there was not much demand for them 5 or 6 years ago when they came out they discontinued them. From what I remember they basically used the AFR Hydra Rev kit then made the rest of the parts to fit the LS1. Also if memory serves me correctly you had to install these in conjunction with the heads, they could not be installed after the fact. I really wanted to get some of these when I eventually did a cam swap, but was under the impression no one else was making them. If someone else is producing these (for the market, not just to tease us with) I would like to know who. I sent ARE an email a few years ago before their downfall suggesting that they either bring these back or possibly sell their design to someone who would produce them since the quest for increasingly larger cams and consequently the increasing need for higher spring pressures might have created a much larger market for these than they enjoyed when they were first released but was blown off. For those that do not see an advantage to these, if designed correctly it would exert spring pressure to the outside of the lifter housing basically simulating a much stronger valve spring while decreasing the amount of spring pressure exerted on the lifter plunger allowing the hydraulic lifter to function much more like it was designed to.
Old Apr 23, 2006 | 08:07 AM
Lasershop's Avatar
By design of the LS1 the heads cover them up. Im still thinking about producing these. I tend to over-design parts that would be fit for a tank and these are no exception. Would have be in the 8-900 dollar range. Need to find me a couple pro built motors headed for a dyno so this design could be proven. Cut a deal.
Old Apr 23, 2006 | 02:53 PM
LS1Tech Sponsor
im looking at a cam that creates power to a lil over 7k thats why i was asking
Old Apr 23, 2006 | 03:20 PM
hammertime's Avatar
What cam are you looking at? Would think that beehive springs and Ti retainers should keep mass low enough that the rev kit is a bit overkill - unless you are running a lot of lift.
Old Apr 23, 2006 | 04:39 PM
LS1Tech Sponsor
off the top of my head i cant remember the specs but it produces power to 7200rpms and has a lift of like .651
Old Apr 23, 2006 | 05:20 PM
hammertime's Avatar
Sounds like a monster - hope this ain't your daily driver.
Problem with a setup like this is getting the right springs for the job once you've put the rev kit in. You'll want something that can handle the lift, but you'll no longer need the high pressures. You may just be able to dump the inner springs, but then does the outer still have enough pressure to suffice?
Also, if you decide to swap cams down the road, your heads will have to come back off to get the rev kit out.
