more effort on cold starts after h.c?
Hello yall, i noticed it takes a litte more work, for the starter to start the car up on cold starts after installed the h/c. Is this normal? I am afraid that i might hurt the life of my starter
LS1 Tech Administrator
It's normal until you get a good tune. Once tuned properly, it should start like normal.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
I could be wrong but adding some compression might also do it. Maybe Patrick could chim in on this. I also agree in most cases a tune will take car of this.
After i added the bbk80mm tb ontop the h.c The more effor start up issue has gotten slightly worser.
How do i fix this in the tune? I have Hp tuners on the way,and also i am running a mail order tune.
Steve
heads and cams require more "running air flow". You need to have youre tuner add more to the RAF table, then you wont have to pedal to get the car started. After letting the car sit and idle warm for a while, youre long idle trims will adjust and give you more air, but its less accurate the further away from 0 your trims get. As for the compression, your started should be fine. Stock starters dont really have much trouble turning 427 strokers with 12.5:1 compression, so im sure itll take care of your motor as long as its in good health. If the started does go, you can find new ones for just over a hundred bucks, and theyre easy to replace.
