ls6 oil pump and slp double roller chain problem
Old Apr 23, 2006 | 12:06 AM
shouldaboughttheZ's Avatar
Default ls6 oil pump and slp double roller chain problem
I am installing a ls6 oil pump and slp double roller timing chain for a friend of mine.
The directions for the chain install back on the crank are not very clear.
Do I need a special tool to put the crank gear for the chain and the timing chain and the oil pump gear? I did a search and came up with a "Kent-Moore #J41665 C'shaft Balancer & Sprocket Installer". I did a search and came up empty handed as far as what it looks like or where I can get one?
Any help would be very appreciated.
Old Apr 23, 2006 | 01:02 AM
eallanboggs's Avatar
No tool required. The sprocket is keyed. You can use the old sprocket you removed to push the new one on the crankshaft. Get the new one started. Be sure the keyway is lined up with the key. Slide it on as far as you can by hand. Buck the old sprocket up against the new one. Tap it home with a rubber mallet or a small hammer and brass knocker. The sprocket bucks up against a boss on the crank when seated fully home.
Old Apr 23, 2006 | 12:05 PM
Thanks for the help. I am going to try that now, I didn't even think about that.
Old Apr 24, 2006 | 06:45 PM
Bill Bowling's Avatar
This is what I did and it worked great.
Bill
Old Apr 24, 2006 | 08:45 PM
NassyVette's Avatar
You can also use the old crank bolt to press the new one on. Pic...
Attached Thumbnails ls6 oil pump and slp double roller chain problem-dsc01187-small-.jpg
Old Jun 8, 2006 | 04:37 PM
Wnts2Go10O's Avatar
im sorry for reviving an d old thread but for all those who read this: put the new sprocket in the oven at 400~* for 10minutes or so and itll slide right on
Old Jun 8, 2006 | 06:11 PM
It slide on fine using the old one and a socket. No oven needed.
Old Jun 8, 2006 | 09:03 PM
TopFlite's Avatar
How did you get away with running green coolant?? Sorry, this is not a hijack.
Old Jun 9, 2006 | 04:04 PM
Talking
I noticed that also...
Bill
Old Jun 9, 2006 | 06:27 PM
NassyVette's Avatar
Bill
It was put in by the previous owner. It's now running dex cool. Good eye
