Intalling Cam..Need help
Old Apr 23, 2006 | 09:44 AM
Spade's Avatar
Default Intalling Cam..Need help
I already have everything apart and put the new cam in. I went to align the dots and can not find the crank dot. I have probably turned the crank 50 times now and no dot. Could I possibly not have a dot? What are my options? Car is a 98 btw
Old Apr 23, 2006 | 09:57 AM
GuitsBoy's Avatar
Ive never heard of not having a dot on the crank. It is a bit tough to see though since its blocked by the oil pump. Might try and clean off any oil from the crank gear with a q-tip or something to help you see it better.
Old Apr 23, 2006 | 10:00 AM
Spade's Avatar
I will try that...good idea..
Old Apr 23, 2006 | 10:01 AM
davered00ss's Avatar
Moderator
The dot is on the Crank gear, not the crank. Are you using an new gear set or reusing the old one?
Old Apr 23, 2006 | 10:11 AM
Spade's Avatar
Sorry if I sounded misleading but I am looking on the crank gear. I am following LS1HowTo instructions. I swear to you that there is no dot. I have cleaned of every tooth and have not seen this dot anywhere. I have a cloyes timing chain and different timing gear.
Old Apr 23, 2006 | 10:13 AM
Moderator
So you can't find the dot on a new gear?
Old Apr 23, 2006 | 10:14 AM
GuitsBoy's Avatar
Ahhhh, aftermarket timing set. Im not familliar with how theyre marked. However, you can always find cylinder 1 TDC by feeling for the piston to come up through the sparkplug hole. You better be damn accurate though and make sure youre cam gear dot it pointing straight down and not off a tooth.
And above all else, make sure you spin the motor over by hand a few times to make sure nothing binds up. You have to be extra careful to do it this way, but it certainly can be done.
Old Apr 23, 2006 | 10:18 AM
Spade's Avatar
Well the heads and everything else under them is already off the car. Just make sure cylinder one is all the way up?
Old Apr 23, 2006 | 10:21 AM
GuitsBoy's Avatar
LOL!!! yes. Top dead center on the front most drivers side piston. Cam gear pointing straight down. No worries at this point!
Old Apr 23, 2006 | 10:23 AM
Spade's Avatar
Sweet...You can never have to much information. Thanks
Old Apr 23, 2006 | 10:41 AM
Spade's Avatar
Final confirmation. I took some pics just to re-verify myself. Does this look good to you guys?
Timing gear dor straight down..
TDC at the same time...
Thoughts?
Old Apr 23, 2006 | 10:44 AM
GuitsBoy's Avatar
Looks good to me.
Old Apr 23, 2006 | 02:51 PM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
Originally Posted by GuitsBoy
Looks good to me.
Ditto.
Old Apr 23, 2006 | 03:01 PM
hammertime's Avatar
May not hurt to see if anyone you know has a degree wheel you can throw on it to check. Aside from seeing that it is installed correctly, you'll be able to verify your cam is ground correctly, and change the lobe centerline angle with that adjustable timing set, if you wish.
Old Apr 23, 2006 | 03:23 PM
Spade's Avatar
There is no one around here that has that. Being overseas as big drawbacks when it comes to car stuff, at least Belgium does. Thanks for advice though.
