Head recommendations for MTI-422
Car is currently running MTI Stage 3 LS1 heads, R1 cam (232/236 .575/.578 114), LS6 intake, stock ported TB, and stock MAF sensor right now. Car is an automatic. Car is basically an "old" setup and I am looking to bring it up to date - including horsepower wise with all the new equipment available now that wasn't when it was built.
I have already purchased a NW 90mm TB and SLP 85mm MAF sensor and was looking into a FAST 90 intake - but started thinking about changing my heads as well. So before I invest in a FAST intake - I was wondering if I should look down the LS7 direction (I know about having to cut pistons) or just stick with one of the newly available heads from the aftermarket made to work with an LS1. If so, which head?
Car is a street car and will remain a street car with occasional strip time. Also, car does have a TNT kit on it - but I rarely use it.
Thanks in advance.
Chris
That cam is tiny for a 422 and the durations dictate how much air comes in.
Custom is the way to go since your motor is already built.
Thanks in advance.
Chris
The FAST 90 will still starve a 422, so the intake will be the weak link. The only intake out there that will accomodate our sized engines is the Harrop intake, but they're expensive as hell. And the only heads that will allow a super-stroker to breath to its max potential are LS7 heads or the ETP 265/41 heads.
So, if money allows, get the Harrop and the ETP 265's or LS7 heads, and upgrade the cam. Expect to put down 600+ RWHP.
I would love if some can pull 600+rwhp from an engine with compression ratio <11.5 and a cam in the 24x range duration. I haven't seen one yet, and no I don't believe the hype about LG's recent LS7 dyno.
That's why I've been planning about going Forced Induction.
You picked generic off the shelf cams. Your motors should have custom cams for the heads you have since both of you have hand ported ones.
Nothing is more reliable than a properly matched NA motor.
XXXhp, your car should be running flat 10's but we both know traction (suspension is an issue).
Also Big cubes are more strangled by the intake setup than anything else.
Power should not be looked at as "peak power" only, but more as power under the curve or as some of us call it "useable" power.
Thanks again.
Chris
