Whats the best cam for AFR 205 heads?
If I decide to keep my car I'm gonna get some AFR's. I already have a heads and cam set up with MMS stage 2 heads and a F4 FMS cam 226/226 575/575 114lsa. I'd wanna get the most out of the AFR heads so I could leave the cam and see how it does with the heads or try to find a better cam. Thanks,
Originally Posted by you2slo
AFR 205's? TTT for ya. I'm interested in some proven combos.
Originally Posted by TXZ28LS1
not to jack your thread, but will reverse split cams work well with the afr heads rather than the traditional split cams?
Originally Posted by tru_ice
I think the formula Tony has been sticking w/ is a 224/228 .581/.588 114 or 112 cam, then milling the heads to a 62cc to raise your CR to 11.2:1. You'll have great driveability and excellent power under the curve. I'm sure Tony will chime in though to give you a better run down.
Pretty close to what I was going to run with my AFR 205's, before I discovered my "disaster", and wound up re-building the entire engine (forged bottom-end stroker), and having to move up to AFR 225's.
With the 205's I had a Comp 224*/228*, .581/.588 on a 114* LSA. I shouldn't say "had"....I still have the cam new-in-the-box. The 205 heads sold in about 30 seconds, but I can't seem to give the cam away.
I have the exact same problem as bichin95redta. I was going to run 205s milled .030 on my stock short with the new "Patrick G" cam but blew away a bearing. I just got the cam today And a shameless plug, it's for sale...https://ls1tech.com/forums/lsx-parts-sale/492468-brand-new-patrick-g-cam-cometics-arp-studs.html
Originally Posted by eamador11
416RWHP, 384RWT, with a flat *** power curve! Power everywhere!
James
Originally Posted by Jimmard
Yeah I rode in a car with a similar setup to yours, only instead of AFRs he had stage 3 LS6 heads. After riding in that thing and getting back in my car, my car felt slooow . I plan on doing AFR heads with an F14 cam, just gotta look into it more before I do it. You wouldn't by chance have a dyno sheet now would you
James
James
good move on AFRs, with a good matching cam your car will make very nice power across the entire board not just at peak.
First, your current cam would probably be fine. Use 1.8 rockers if you want to make it a little more aggressive.
Otherwise, Patrick G has been playing with a cam similar to a Trak with LSK lobes on both intake and exhaust and the smaller 223/227 durations.
First, you need to determine the operating range of your engine. If you care about 4000-7000 and don't care if will run in traffic, you could go in the 240s. However, if you want something that won't wake the neighbors yet power peak over 6000, then something in the 220-230 range with may be a 4° or so split will work.
Another wild card is emissions. If you have to pass, you are also going to be looking at something in the 220-224 range with a wider 114 or so LSA.
