Flycutting?
Old Apr 25, 2006 | 10:38 PM
Cbrakllr's Avatar
Default Flycutting?
All right, I'am going to be purchasing the TTPerformance stage 4 heads and cam combo. It says that flycutting is required, thats all good but what is flycutting? Sorry for the neebie questions but i have nevee had to do this before. What do they do when they flycut? Also can you do it, or does a machine shop have to do it?Thanks for the help in advance.
Old Apr 25, 2006 | 10:50 PM
just-a-z's Avatar
http://www.ffhp.net/tech_Isky.htm
Hope that helps a little
Old Apr 25, 2006 | 10:53 PM
bigdsz's Avatar
It is notching your pistons so that there will be no P/V contact with larger cams. You can do it yourself. we need alot more info cam size, combustion chamber cc, Etc. The guy that is selling you this combo should have given you this information.
Old Apr 26, 2006 | 08:56 AM
GuitsBoy's Avatar
Not to be insulting, but if youre not sure what flycutting means, are you sure you want to go with something this agressive? Dont get cought up in HP numbers, as theres a lot more to the story. Some of the highest HP cars feel really soft on the street because they lose so much low end torque due to the monster cams. On second though, looking at your sig it looks like this might be a track car and you know exactly what youre getting yourself into.
Like the others said, its notching the pistons. To do it yourself you need the isky cutter and a junk head with the valve seats pulled out. LG motorsports will rent you both. Youll also need a drill with the smallest 90* angle attachment you can find.
Old Apr 26, 2006 | 11:55 AM
Cbrakllr's Avatar
Well it is my D.D but rarely driven, i have not ordered the combo yet but I do not know what the specs on the cam are. The keep it secret. It is from ttperformance.
Old Apr 26, 2006 | 12:05 PM
SHINER's Avatar
fly cutting is when you make a certain "cc" of relief for your valves on the piston head using a certain tool which this process help accomodate cams with high lifts to avoid piston to valve collision. Which will in deed **** your motor up.
Old Apr 26, 2006 | 12:09 PM
Fireball's Avatar
WRONG. its not the high lifts, its the overlap conditions-when the intake and exhaust valves are open at TDC
Old Apr 26, 2006 | 12:38 PM
SHINER's Avatar
my bad thanks for correcting me!
Old Apr 26, 2006 | 01:18 PM
Cbrakllr's Avatar
What if instaed of going with their combo I just bought their heads and then went with the MS3? Would I still need to flycut? Is it all in the heads?
Old Apr 26, 2006 | 01:40 PM
GuitsBoy's Avatar
If youre certain that you do indeed want to go this big on the h/c setup, then yes, id take a look at the MS3 and a set of LS6 heads. Depending on the heads and valves used, you probably dont have to flycut.
Old Apr 26, 2006 | 03:17 PM
SHINER's Avatar
Ported LS6 heads are making some insane numbers on the dyno. Id go with ported LS6 heads, and MS3. Thats a really nice setup.
Old Apr 26, 2006 | 05:16 PM
sickss228's Avatar
I agree that sounds like a very strong setup, but it would be nice to see if the TTP package puts down close to what they claim.
Old Apr 26, 2006 | 05:27 PM
Cbrakllr's Avatar
Where can I get the best set of ported LS6 heads? Also will I need to flycut if i go with ls6 heads and an MS3?
Old Apr 26, 2006 | 05:31 PM
SHINER's Avatar
i dunno if you wanna spend the money goto MTI
Old Apr 26, 2006 | 06:10 PM
SideStep's Avatar
I had a set of MTI heads... If you are dead set on LS6 heads look to TEA...
Old Apr 26, 2006 | 06:18 PM
SHINER's Avatar
well they ya go!
Old Apr 26, 2006 | 06:42 PM
DocEwww's Avatar
Yes, the heads in the combo are AFR 225s ported and I believe milled by TTP. Their V4 cam is slightly larger than the MS3 from what I understand.
Old Apr 26, 2006 | 06:48 PM
SHINER's Avatar
go with that set up! AFR makes badass heads
Old Apr 26, 2006 | 06:54 PM
DocEwww's Avatar
It mad 505rwhp in one of their customer cars and was the record holder for the stock bottom end until recently.
Old Apr 26, 2006 | 09:43 PM
Cbrakllr's Avatar
Ya i saw it made 505hp in their car, but its not that numbers that get me to buy the package its the time, with just their h/c combo, headers, and a turbo 350 they ran 10.33. So that basicallly sold me. Plus they has 4.10's. now throw a 75 shot and you could have a 9sec stock bottom end for a lil while. LOL.
