Most NA HP & pass the sniff
Old Apr 26, 2006 | 07:51 AM
M2SPEED's Avatar
Default Most NA HP & pass the sniff
What is the most hp that can be expected from a non stroked, without funny gas, natural aspirated 5.7L LS engine?
From what I’ve seen so far is about 435 rwhp. Is this about the limit?
Old Apr 26, 2006 | 11:55 AM
M2SPEED's Avatar
I believe from the other posts on here that cut-off point to pass the sniff test is around 228 cam duration. So if someone is quoting 450 hp or something like that with a 235 cam its really doubtful they passed the sniff test without there being a payoff being involved. Right or Wrong?
Old Apr 26, 2006 | 12:05 PM
PREDATOR-Z's Avatar
Comfy sniff teast cutoff is -6>-7 degrees of .050 overlap and a GOOD tune.
Old Apr 26, 2006 | 12:12 PM
SHINER's Avatar
its usually the LSA that people have trouble passing emissions with, i heard 112 is the max
Old Apr 26, 2006 | 12:24 PM
BLKWS.6's Avatar
I have heard of cars w/no cats dropping timing WAY DOWN and running alcohol and passing. Dunno if there is any truth to it.
Old Apr 26, 2006 | 12:53 PM
PREDATOR-Z's Avatar
YES it is LSA related but has to do with OVERLAP.
As mentionned above -6>-7 overlap is a sure bet with good tune.
There has been as low as -4 overlap that passed but that tuner must have done a really good job.
Old Apr 26, 2006 | 12:55 PM
M2SPEED's Avatar
I think the LSA plays a bigger part than duration but from what I have read here 228 is about it with 113 or 114 lsa.
One question I have: Is it the exhaust duration or the intake duration that is the main concern, or is it both equally to be concerned about? Is a split duration cam like 224/230 or a reverse split better in regards to emissions 230/224 than maybe a 228/228?
Old Apr 26, 2006 | 01:14 PM
PREDATOR-Z's Avatar
GUYS<
READ MY LIPS
IT HAS TO DO WITH OVERLAP.
OVERLAP @ .050 = (INTAKE DUR + EXHAUST DUR)/2 - 2X LSA
FOR A 228/228 TO PASS
(228+228)/2 - 2X LSA = -6
228 - 2X LSA = -6
228 + 6 = 2X LSA
(228 + 6)/2 = LSA
234/2 = LSA
117 = LSA
So your LSA on the 228/228 cam should be 117 to have any hope of passing with a GOOD trick tune.
In reality this will be a shitty cam that spins to neverland.
Old Apr 26, 2006 | 01:22 PM
SHINER's Avatar
hahahaha
Old Apr 26, 2006 | 06:02 PM
M2SPEED's Avatar
GUYS<
READ MY LIPS
228 - 2X LSA = -6
228 + 6 = 2X LSA
(228 + 6)/2 = LSA
234/2 = LSA
117 = LSA
Equation A (Cut-off point to pass sniff test)
228 - 2X LSA = -6
228 + 6 = 2X LSA
(228 + 6)/2 = LSA
234/2 = LSA
117 = LSA
Equation B (Cut-off point to pass sniff)
(224+224)/2 – 2X LSA=-6
224 - 2X LSA = -6
224 + 6 = 2X LSA
(224+6)/2 = LSA
230/2 = LSA
115 = LSA
Proven fact TR224 224/224 LSA 114 passes sniff test easy with room to spare.
Equation B = false
If Equation B = false then Equation A = false
Equation C (Cut-off point to pass sniff)
(224 + 224)/2 – 2X LSA= -4
224 - 2X LSA = -4
224 + 4 = 2X LSA
(224+4)/2 = LSA
228/2 = LSA
114 = LSA = proven statement
-4 for sure maybe, –3 or even –2 for the fixed variable in these equations.
Responding to read my lips
Old Apr 26, 2006 | 07:44 PM
John B's Avatar
Moderator
My forged 347 LS6 with a CARTEK 3X cam (mid 230° duration) passed with cats on and this combo was putting out 440/386 RWHP/RWTQ.
Old Apr 27, 2006 | 01:11 AM
PREDATOR-Z's Avatar
228 - 2X LSA = -6
228 + 6 = 2X LSA
(228 + 6)/2 = LSA
234/2 = LSA
117 = LSA
224 - 2X LSA = -6
224 + 6 = 2X LSA
(224+6)/2 = LSA
230/2 = LSA
115 = LSA
Equation B = false
224 - 2X LSA = -4
224 + 4 = 2X LSA
(224+4)/2 = LSA
228/2 = LSA
I said comfy sniff passing and 224 / 114LSA doesnt pass with room to spare, but passes with a good tune. Search, you'll find reports of 224/114 failing too.
A 224/ 112 will fail.
I was trying to explain the way to find overlap and not "I heard this and I heard that."
There has been records of 228 passing.
And a 228 with -4 overlap has but a slim chance to pass.
At -6/-7* overlap you cannot fail if everything running like it should.
Old Apr 27, 2006 | 07:51 AM
SHINER's Avatar
so how the hell do u get inspected with a 112 LSA and pass with out paying someone off.
Old May 1, 2006 | 05:23 PM
Dip Stick's Avatar
Ok, so with the VE calculator I was playing around with my numbers.
228/228 .588/.588 @112 ICL 110
The overlap is 4 degrees.
I guess the lingo is what is getting me.. as low as -4? if the -6/-7 is the cut-off wouldnt it be as high as -4? assuming +4 overlap > -4 overlap?
Thus the 228R @112 +2 wouldn't pass smog/emissions ?
Old May 2, 2006 | 12:08 AM
LoWeLL216's Avatar
Just to throw out my .02... My 99' passes CA smog with a TR 224/224 114 easily on the stock tune.
Old May 2, 2006 | 12:09 AM
PREDATOR-Z's Avatar
Nope, wouldn't pass
