View Poll Results: Which of these 4 cams is KING of big cams?
TRex
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
140
41.92%
MS3
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
101
30.24%
F15
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
19
5.69%
G5X4
![](https://ls1tech.com/forums/images/polls/bar5-l.gif)
![](https://ls1tech.com/forums/images/polls/bar5.gif)
![](https://ls1tech.com/forums/images/polls/bar5-r.gif)
74
22.16%
Voters: 334. You may not vote on this poll
TRex vs. MS3 vs. F15 vs. G5X4
Originally Posted by CRL 01 SS
MS3, Full Bolt-Ons with FAST 90/NW 90, and stock heads. Moser 9" rearend with 315s. Car has a M6.
Motor: 411 rwhp/370 rwtq
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](http://img50.imageshack.us/img50/7050/dynocustom2og.th.png)
Originally Posted by HaulinHawk
Someone post some times,dyno #'s dont mean squat!!! ![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
Originally Posted by SVT THIS
Thanks for the graph! Those are impressive numbers and not a bad time for a 2 sec '60. I wonder how the X4 would work with a set of CNC LS6 heads. Anyone have number with that? Or any other setup with these cams and heads?
Those are nice numbers with a G5X4. I'm assuming that those numbers were made through a 10 bolt? I figure that my 9" is eating up atleast 15 rwhp/15 rwtq. With just the MS3 I only gained 10 rwhp/6 rwtq from the FAST 90/NW 90 over my LS6 intake and ported stock TB. Not disappointed, but I expected a little more. It would work a lot better if I put some better heads on there.
How would a custom 239/247 .649/656 109LSA+1 cam (high lift TRex) work with the LS6 heads? Would the torque numbers be better than 400 due to the increase in DCR? I believe that the power curve would look much better and still have pretty impressive peak numbers. Someone correct me if I'm wrong. Also, what springs would be required with a cam with lift that high?
#33
Yes they will be on LSK lobes. My question is what type of springs will I need? Will Patriots dual spings good to .650 lift be enough or since that cam lifts to .656 will I need better springs? If so, which ones? Thanks
#36
Originally Posted by PREDATOR-Z
Look at that low trq, a true indication of overcamming on a low DCR.
425 but 370 trq (should be 425/ ~400 trq)
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#38
I've looked around at some sponsor's sites and I can only find PRC springs good to .660 lift. Is there a site you know of that sells them??
#39
Retired Street Racer
Originally Posted by steveb
I agree 100%, the MS3 has proven time and time agian it can't produce good numbers. ![Bulls#!t](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bs.gif)
Explain to me how my MS3 powered Camaro with only 360hp/300tq went 10.85@126.4 with stock heads, LS6 Intake, ported TB, and 3275 raceweight and +1500 DA?
#40
Originally Posted by 4thGenCamaro
I HATE when people type this ****. It pisses me off. Dynos are for tuning, not bench racing. Track numbers are different. The X4 for your information, is smaller than the MS3 on both Duration and Lift. Bigger for both doesn't always mean better numbers. The MS3 is just as good as the TREX and X4.
