View Poll Results: Which of these 4 cams is KING of big cams?
TRex
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
140
41.92%
MS3
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
101
30.24%
F15
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
19
5.69%
G5X4
![](https://ls1tech.com/forums/images/polls/bar5-l.gif)
![](https://ls1tech.com/forums/images/polls/bar5.gif)
![](https://ls1tech.com/forums/images/polls/bar5-r.gif)
74
22.16%
Voters: 334. You may not vote on this poll
TRex vs. MS3 vs. F15 vs. G5X4
#42
Originally Posted by 4thGenCamaro
What's a high stall??? ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
And I shift at 6800
And I shift at 6800
#44
I meant what is high in stall size to you. Yes, it has a converter and stock gears. It is all about how the car is setup. You won't go fast if you can't get the power to the ground. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
or 3800 with Transbrake / PB valve
#47
I HATE when people type this ****. It pisses me off. Dynos are for tuning, not bench racing. Track numbers are different. The X4 for your information, is smaller than the MS3 on both Duration and Lift. Bigger for both doesn't always mean better numbers. The MS3 is just as good as the TREX and X4.
Explain to me how my MS3 powered Camaro with only 360hp/300tq went 10.85@126.4 with stock heads, LS6 Intake, ported TB, and 3275 raceweight and +1500 DA?
![Bulls#!t](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bs.gif)
The other giveaway is they actually have a MS3 listed in their sig............
#49
Damn you're good ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I'm an old timer at this, yet learning everyday, I LOOOVE drag.
#50
There was more than one person who said it....
But hay what do I know.
#51
Retired Street Racer
Originally Posted by PREDATOR-Z
That is because I use a Proportioning valve with my VIG 3200 and nitrous, that way I can brake stall higher than any one could normaly. I can cut 1.5 60' and ran a 11.13 @ 122 NA with the TRQR V2/PRC 2.5 etc... and mid low 10's on juice.
#54
Originally Posted by 300bhp/ton
ummm I think you miss read their reply. Note the
flag, I suspect they where being sarcastic as someone else said the MS3 didn't make the power and they simply replied with a sarcastic remark.
#57
Originally Posted by SVT THIS
How would a custom 239/247 .649/656 109LSA+1 cam (high lift TRex) work with the LS6 heads? Would the torque numbers be better than 400 due to the increase in DCR? I believe that the power curve would look much better and still have pretty impressive peak numbers. Someone correct me if I'm wrong. Also, what springs would be required with a cam with lift that high?
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
good thread, i will be *hopefully* getting myself a cam soon... someone mentioned the "texas giant"... i thought that was the Trex... am i missing something?
#58
yeah, the texas giant is a stroker cam..something like 248/254 i think..on a default lsa of 113..
the reason you can run MORE lift with that particular cam (239/247 .649/656 109LSA+1) is because of the LSK lobes being used. they close FASTER than pretty much every other lobe i've seen on the market for an lsx cam. thanks to patrick g i have re-thought my custom cam, and lsk lobes are now a big part of it.
#60
i think i might do some more thinkin as well... does Patrick G sell/grind cams?
