Help, missfire between 2500-4000 WTF!!!!!
Hey guys, I got a SS that has been misfiring since I got it. Got a new driver side cat and rear sensor and still same problem, when you open it up engine light comes on, but it misfires all the time between 25-4000rpm. When engine light comes on code is always the same. As long as you drive easy the engine light does not come on. Any ideas???? Thanks.
Hello, new wires, plugs, fuel filter, rh cat and rear o2 sensor, under hard accelleration it misses, if I roll on it usually takes the gas ok??? All car has is a LID and Flowmaster cat back. Thanks.
