texas speed ls6 heads
Old May 3, 2006 | 11:19 PM
Slow00ls1T/a's Avatar
Default texas speed ls6 heads
Do the valve springs come already assembled bc i ordered them with comp 918s and want to make sure they are comp 918s that are installed
Old May 3, 2006 | 11:58 PM
UltraZLS1's Avatar
they come installed.....I have the same heads/springs.
They should have a blue stripe on them.
Old May 4, 2006 | 12:01 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Most "complete" well, all "complete" heads come with everything installed. Bolt em' on and go...........get the car tuned.
Old May 4, 2006 | 12:03 AM
They dont have a blue stripe on them when i recieved my cam today it had a box of comp 918 springs so does it just now only have the ls6 springs and i have to install the comp 918s
Old May 4, 2006 | 12:06 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Apparently looking like it now.
Old May 4, 2006 | 12:09 AM
I bought assembled heads with comp 918s installed not assembeled heads with ls6 heads and im gonna have to install these springs
Old May 4, 2006 | 02:32 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Old May 4, 2006 | 03:14 AM
a little frustration was let out in that previous post meant to put ls6 springs not heads
Old May 4, 2006 | 03:26 AM
PREDATOR-Z's Avatar
It is not a big deal.
Just get a C-clip spring clamp (old style) and change them.
think of it this way, you got an extra set of LS6 springs for your labor fee. You can sell those and recup some $$.
Old May 4, 2006 | 09:21 AM
are these accesable at like at a discount or auto zone
Old May 4, 2006 | 09:24 AM
PREDATOR-Z's Avatar
Anywhere they have parts.
Old May 4, 2006 | 10:14 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We install springs on the heads when they're ordered all together!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old May 4, 2006 | 10:36 AM
I recieved a box of comp 918 springs when i recieved my cam in a few days later and from what it looks like these dont look like comp 918s that are on the head
Old May 4, 2006 | 11:13 AM
fast98's Avatar
what do the ls6 springs look like that come on these heads..............mine had a blue stripe.
Old May 4, 2006 | 11:56 AM
mine dont have a blue stripe the ones with blue stripes are the comp 918s but i could be wrong
Old May 4, 2006 | 01:55 PM
fast98's Avatar
ya thats what i thought..............
Old May 4, 2006 | 06:24 PM
UltraZLS1's Avatar
I dont understand.
If you ordered the heads and selected the comp 918 springs option they should have came installed and had a blue stripe on them.
If you ordered them seperate then they would not be installed but should have a blue stripe. I think some of the ls6 springs are yellow depending on the year.
If you already received the 918's when you ordered the cam then you must have ordered them separate.
I am confused here.
Old May 4, 2006 | 06:44 PM
steveb's Avatar
Just call and ask them, its pretty easy and they have great customer service.
Steve
Old May 4, 2006 | 11:22 PM
ya what had happen was there was a mix up on the order
