Still consuming oil
Old May 4, 2006 | 08:37 AM
HASTINGSRJ's Avatar
Unhappy Still consuming oil
Well since my motor build, there is about 5k on the car. I was consuming oil when I was running 10w30. I switched to 10w40 now, thinking that would solve the problem. I had to put 1.5 quarts in it yesterday. The car hasnt been tuned yet though. Will a tune help me out with this problem? Mods are in my sig. Thanks for any help/input on this subject.
rob
Old May 4, 2006 | 08:45 AM
HASTINGSRJ's Avatar
for the first 500 miles I ran regualar non synthetic 10w30. The block was honed, cleaned, new bearings and I put new piston rings in it. After 500 miles I switched to Mobile 1 10w30. Now I am running Castrol syntech 10w40.
Old May 4, 2006 | 08:47 AM
JakeY2KZ's Avatar
Maybe the rings didn't seat right. Have you done a compression/leakdown test on it?
Old May 4, 2006 | 08:51 AM
HASTINGSRJ's Avatar
not yet...Guess I will have to try that.....
Old May 5, 2006 | 07:35 AM
HASTINGSRJ's Avatar
anyone else???
Old May 5, 2006 | 07:40 AM
ls1mn6_3's Avatar
What's your PCV situation? I was sucking it down to the tune of 1qt. per 2000 miles. I then purchased the $37 GM upgrade kit which relocates the pick up to the front with a new valley cover and I don't add a drop in between changes now. I think the F body got the upgrade as stock in '01. Hope that helps.
Old May 5, 2006 | 07:41 AM
black01_WS6's Avatar
Did you take out your PVC system, if so it can consume some oil, maybe look into a catch can or a metco breather filter. I would try those first.
Old May 5, 2006 | 10:25 AM
HASTINGSRJ's Avatar
Well I deleted the PCV. I got the breather for the oil cap, and put a small breather on the drivers side valve cover where the PVC goes in, then capped up all the rest of the lines that come out of the valve cover, intake.
Old May 5, 2006 | 10:29 AM
HASTINGSRJ's Avatar
I got this:
Old May 5, 2006 | 10:43 AM
Galen's Avatar
Mine is drinking oil due to some head sealing issues. I popped my intake off to check out the intake valves and had oil sitting on them. Some pics are in this thread. https://ls1tech.com/forums/generation-iii-internal-engine/496219-darts-worth-600-more-than-tsp-s-ls6-heads.html
I just want you to be able to rule out the top end of the motor. Good luck!
Galen
Old May 5, 2006 | 10:51 AM
HASTINGSRJ's Avatar
Originally Posted by Galen
Mine is drinking oil due to some head sealing issues. I popped my intake off to check out the intake valves and had oil sitting on them. Some pics are in this thread. https://ls1tech.com/forums/showthread.php?t=496219
Galen
thanks for the info.....
Old May 7, 2006 | 09:29 PM
Rob Hood's Avatar
What is this $37 GM upgrade kit?? Got a part number? Will it work on my 01 HD 6.0 as well?
Old May 9, 2006 | 06:55 AM
HASTINGSRJ's Avatar
yeah, I am curious about that too......
Old May 9, 2006 | 07:48 AM
Z'mnypit's Avatar
I beleive he's talking about the LS6 PCV conversion. With the LS6 conversion the pick up will be in the front of the valley cover.
Old May 10, 2006 | 06:05 AM
ls1mn6_3's Avatar
The part # for the new valley cover with the PCV pick up in the front of the motor is #12568002. I paid $37, it is apparently around $45 now. You will still need the hoses however. I have a list of part numbers that I ordered at the same time. I don't remember anymore which is which, this was 4 years ago. Good luck.
12568002
12572717
25170361
12568010
12568478
12563325
Old May 12, 2006 | 07:53 PM
HASTINGSRJ's Avatar
well I am going to try regular non synthetic oil, see if that helps my problem. I didnt get to do a compression test this past weekend, death in the family
